i'm new here so dont mind me asking this if it was already asked b4. okay here is my problem.. when the car starts to boost, the car would jerk and bog like fuel cut or something. if you depress the gas pedal the car would hesitate and jerk. but if you just touch the gas it would boost fine until 4500rpm the it hesitate and starts jerking. i checked the turbo for play and there is little in/out and left/right play. but not enough to make the turbo bad. any ideas or advice to whats going on with my car?? thanks
Generally this type of thing is one of three things:
1. Ignition ~ how old are the cap, rotor, wires and plugs? What kind of plugs?
2. BOVs ~ aftermarket BOVs can really make the car run poorly. On that line, I would also be worried about boost leaks in the system.
3. AFM ~ Did you play with your AFM at all? If you undid the 2 screws on the side of it you could have damaged the unit and that would cause lots of problems.
have not checked the cap/rotor or plugs yet.. the car is stock with no aftermarket parts of any kind. and i did not mess with the afm either.. it just jerks and hesitates when boost starts to build.. also boost gauge will drop to 0. really need to know whats up b4 i start tearing everything apart. thanks all
crankshaft work? thats quite a diagnosis from a distance....so you want him to pull the motor and crankshaft because the engine bogs some???? I just learned a new term yesterday.I think it applies -Troll
you are so frikin funny. It happend to me 4 months ago and to a frend of mine 1 weeks ago, and the way you would check the crank usually you would pull the exh. pippes out than the oil pan and than wala magically the crank is right there. Now go and tell your friends the new trick you lernd.(and yes i have taken the holle motor apart and put it together). Looser
how could it be the crank?? it drives fine just doesnt boost well. its cuts when gas is applied harder then normal driving.. it will boost till redline if u just keep your feet at a certin point.
it also eats a grip of gas and it backfires often. i have a feeling that it may be getting too much fuel and then boost cut or turbine wastegate not holding. i mean the car idles fine doesnt misfire. oh yeah also when it start to boost and then boggs the boost gauge would drop to negative. shouldnt the boost gauge raise to postive when revving? because im not getting that when i rev. thanks for all your opinions .. still need help thanks
just trying to keep this guy from doing alot of work for nothing...
pippes - pipes
lernd - learned
holle - whole
so on and so forth.
Sorry for critiquing, but i can't take you seriously with spelling errors like that man.
__________________ 04 WRB STi - Stg. 2 93 White Mr2T - 263 rwhp @ 10psi 95 Black Mr2T - TKO exhaust 04 Suzuki GSX-R600
