Yes I did touch the screws when I was trying figure out the problem, but I have tested the MAF and it is working correctly according to my mr2 manual. Now my car won't even try to start. It's cranks, and it is getting fuel pressure, and spark, but it is not firing, I have checked compression and all cylinders are right around 170 PSI. I have checked codes and the only one that comes up is code 43 (no STA signal to my ecu engine speed reaches 800 rpm whith vehicle not moving), but I don't think this has anything to do with my problem. WHAT DO I DO NOW?
