what rpm should i leave at Jekyl? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-27-2005, 08:00 AM   #1 (permalink)
View clem's Photo Gallery
Am gonna debut my jdm mr2 at the track this weekend and was wondering what rpm i should leave at? the lenth of our track is 1000 feet !
clem is offline   Reply With Quote
Old 10-27-2005, 08:43 AM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
every car is different and it also depends on driver skill....get a few practice runs in first before you can determine your optimal launch rpms....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 10-27-2005, 09:21 AM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Is this a basically stock turbo MR2?
A good palce to start is 5000-5500 rpms with clutch slip or else you will spin them.
What tires are you using? (tpye and size).
Is this a prepared track or street surface?
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 10-27-2005, 12:15 PM   #4 (permalink)
View semi-charmed's Photo Gallery
so basically J&H you're saying, in general of course, a good way to start off the line is to rev her up between 5000-5500 rpms and then ease the clutch in as opposed to just dumping it?
also, when accelerating through the drag...where should your shift points be...i know this all depends on your car and your tuning setup...but let's say for a mostly stock MR2 turbo
semi-charmed is offline   Reply With Quote
Old 10-27-2005, 12:32 PM   #5 (permalink)
I love Cin
Dumping the clutch is almost never ideal.
Shift points, this is a quote of me from the mr2oc.com:
Originally Posted by JekylandHyde
***EDIT** There was an incorect gera ratio listed in here.
Teh correct 3rd gear ratio is 1.258:1
Please feel free to post anything that contradicts the following information. I am merely sharing what my research has found.
Nothing below is written in stone (As far as I know )
Shift point information:
http://www.lingenfelter.com/shiftpoint.asp
http://www.allpar.com/eek/hp-vs-torque.html
http://realbig.com/miata/miata/1995-12/910.html
Using the formula on the third link, my car should be optimally shifted well beyond redline ... and I do shift at redline.
Formula:
Lower gear ratio / higher gear ratio X RPM at peak Torque = Shift RPM
Using the same formula for a stock CT26 MR2, I get shift points:
1st --> 2nd = 6595 rpms
2nd --> 3rd = 5643 rpms
3rd --> 4th = 5595 rpms
4th --> 5th = 4915 rpms
Hope that helps.
Notice how the following both have the peak torque at the same RPM?
276 HP CT26
http://www.turboforum.net/dyno/image...ns/dyno276.jpg
161 HP CT26:
http://www.turboforum.net/dyno/image...redmr2dyno.gif
Same turbo, same shift points
Old 10-27-2005, 12:35 PM   #6 (permalink)
i have hks cams 264`s on the intake and the exhaust upgraded exhaust a hks intake and i am running 10 pounds of boost!
Old 10-27-2005, 03:17 PM   #7 (permalink)
Rockin the STi
View onehotcamry's Photo Gallery
man, turn that boost up a little. Your car can take it. A stock mr2 can take it.
04 WRB STi - Stg. 2
93 White Mr2T - 263 rwhp @ 10psi
95 Black Mr2T - TKO exhaust
04 Suzuki GSX-R600
onehotcamry is offline   Reply With Quote
Old 10-27-2005, 04:09 PM   #8 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Yea.... a good condition MR2 will run up to 12psi.... why are you limiting it to 10?
Old 10-27-2005, 04:31 PM   #9 (permalink)
I calculated the shift points for the N/A 5S-FE using the same formula above:
1st --> 2nd = 7374 rpm
2nd --> 3rd = 6523 rpm
3rd --> 4th = 5658 rpm
4th --> 5th = 5516 rpm
Just in case anyone's interested
Old 10-27-2005, 07:03 PM   #10 (permalink)
Toyota Fiend
View glish_dreams's Photo Gallery
if you cant get ahold of a shift light.. if i was you.. id find out which RPMs you can speed shift..
you know what that is right.. shifting without the clutch.. doing that on drag strips give you good time...
other then that.. id just runn the gears out as long as you can.. pretty much go for the redline half way mark..
glish_dreams is offline   Reply With Quote
Old 10-27-2005, 08:35 PM   #11 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
if you go redline in every gear, you will miss your optimum shift/torque points..thats where the power is to pull you thru the next gear quickly.not to mention over reving the engine and shortening it's life.
clem, take the Doc's advice, there's a reason he takes home all those tropheys.
The Jedi Speeder at CarDomain
Old 10-27-2005, 08:41 PM   #12 (permalink)
Piddy's Avatar
You are stupid...
Old 10-27-2005, 08:46 PM   #13 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Old 10-28-2005, 02:23 AM   #14 (permalink)
Toyota Fiend
well its the way iv always done it on my 4g63 mitsubishi motor . DOCH 2.0L 180-195hp 205tq
rpm0-9speed 0-145
boost -3 0 7 14
rpms 7red start
8middle----id shift right about here..
9last red line
never had a problem.. and i always won, even if i didnt on take off..
Old 10-28-2005, 02:30 AM   #15 (permalink)
Piddy's Avatar
Well I suppose if you have a 80hp advantage on the 4 door, single cam civic you are racing.... you can still drive like an idiot and win.
You should search around and get a feel for the forum before you go posting stupid comments. Especially when it is explained several times in the very thread that you are posting in as to why your comment is stupid. And if you think shifting without the clutch is faster and/or cool.... you are an even bigger idiot. Peel your eyes away from the movie screen..... we are real people... with real cars... that go real fast. Welcome to the MR2 section of ToyotaNation
Now lets get back on topic...
Yikes!! I dunno about that. The redline on NAs is around 6,200rpms. Plus the 5sfe kind of falls off around 5,500rpms anyways. You might want to redo your math before you hit the strip.
