P/s??? Help!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2005, 07:53 PM   #1 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
View Zero turbo's Photo Gallery
P/s??? Help!!!!
My car sometimes turns the dash light of P/S is that !!
Zero turbo is offline   Reply With Quote
Old 10-30-2005, 08:07 PM   #2 (permalink)
View mr3sgte's Photo Gallery
check your power steering fluid...you might be running low of it
mr3sgte is offline   Reply With Quote
Old 10-31-2005, 11:22 AM   #3 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
Ok thx man
Old 10-31-2005, 11:28 AM   #4 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
its your brake fluid most likely...if its your emergency brake light coming on...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 11-02-2005, 10:09 AM   #5 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
yes i do the emergency light on OMG!!!!
Old 11-02-2005, 03:53 PM   #6 (permalink)
View Gairloch's Photo Gallery
Do you actually have both the brake light and the P/S light are both coming on? If so, that means you have two separate issues as they don't use the same reservoir.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 11-02-2005, 03:59 PM   #7 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
the P/S light some times come up and other times it wont . and the emergency brake light is ALWAYS on .
Old 11-02-2005, 04:06 PM   #8 (permalink)
What did the P/S fluid level look like? Make sure you actually look under the cap. I had a car run dry once because the plastic reservoir was stained from the fluid so it looked fine.
The e-brake does not use your hydraulic braking system, it's purely cable. If your brake pads aren't dragging at all this means there is something likely wrong with the sensor.
