I am looking at getting 15" bronze 5zigen FN01R-C rims for my 91 mr2.
+42mm offset.. I am wondering if the offset is about right and if the stager matters..
stock on my car was 195/60-14 front and 205/60-14 rear the ones im looking at would be
205/50-15 front and 225/50-15 rear.. does anyone know if the front to rear stager really matters and would it be better to go like 205/50-15 all the way around or even the 225/50-15 all the way around.. Or does having skinner tires up front help the steering/ cornering?
thx
Enrique
__________________ They have done studies you know. 60%of the time it works everytime. -=SEX PANTHER=-
i personally dont agree that stagger matters all that much, i say if its more of a personal preference than anything else, i plan on going with 225's all the way around also so go for it
complete JDM Gen 2 engine, Tubular stainless manifold and 3" downpipe, Turbo XS Type H RFL blow-off-valve, Konig Holes 17" rims, Faze Boost Gauge, soon: HKS Vein Pressure Converter & Fuel Cut Defender, KYB AGX Struts, RS*R RACE Springs
How much tire stagger matters will depend on what kind of driving you do. For normal street driving it makes minimal difference 99% of the time. If you drive on a track or if "spirited" is a good descriptor for how you drive normally then the stagger matters more.
If I'm not mistaken what it does is help keep the steering of the car neutral. You want the traction of all 4 tires to break at about the same g force load during cornering so you don't have unexpected oversteer. Can anyone back me up on this or explain if my understanding is incorrect?
BTW, I've got the same suspension you do 91RED3S. How do you like yours?
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
The MKII was designed for staggered tire widths.
Going with the same size all around is going to increase the tendency to oversteer in a car that already has the tendency to oversteer.
I have seen at least two MR2s that bought "rim and tire deals" that came with the same size tires all around that ended up wrecked.
It's your car, it's your choice. I would never run the same size tire on a MKII.
If anything, my preference is to go to a larger stagger.
front will be fine ...I'm running 17 x7 205/40 with no probs. I don't remember the offset..somewhere between +38 & +42.....
as for the rear, hieght is OK, but thats a pretty wide tire. not sure....might be OK with that offset...
Thanks for the info guys hopfully I can wrap up my questions before my post is completely hijacked.. So I will go with the stagger for sure.. So I will go with..
Front 15" 5zigen +42MM 205 50 15 (prolly nitto nt450's)
Rear 15" 5zigen +42MM 225 50 15
Unless anyone has any other ideas...
but this will have to all wait till summer because as of today the car is into storage mode What can i say its minnesota....
Thanks guys!!
Erique da frique
I agree with Hyde, a healthy stagger is good, more is better - at least 2 tires sizes between front and rear.
I've driven an MKII with 215/40-17s all around and it was a handful to drive, felt like a slippery bar of soap in the rear while the front was planted. I've staggered everything on my wheel setup: width, size & aspect ratio - and it's great.
I'm pretty sure this question has been answered, but I'll add my $0.02 I think stagger is crucial.
When I got my rims and tires, honestly I got the sizes mostly for the looks, but I soon started autocrossing afterward. I noticed a huge difference when I switched back and forth from my 17's (245 rears) to my stock 14's (205 rears). With the 245 rears, the rear end just feels a lot more planted to the ground. The point at which the rear tires reach their limit is higher than that of the fronts, which helps a car that wants to naturally oversteer.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
My hillclimb set up is 265 rear and 225 front (talk about stagger ).
The result of this is a very well planted rear end and I only get oversteer if I make it happen with the throttle. The car is incredible predicatable.
lol ... of course my drag set up is 275 rear and 165 front, but that has nothing to do with handling
