Originally Posted by mlambrecht
I have a '89 mr2 with the 1600cc, (not supercharged), and it won't stay running, most the time it will not start and when it does start it runs really bad and only for about 30 seconds. I know it is getting gas and getting good spark but can't figure it out. It was running fine and then put it up in garage for about 3 months and just doesn't want to run. Any help would be appreciated.
3 months isn't that long sitting however, if you have good spark in "all" the cylinders, good air flow and getting fuel. "I" would next check the fuel condition. You could have got water mixed with the gas from condensation build-up. This can happen if tank left low on gas. I would also check the throttle body ports/hoses/vaccume lines.....then sensors
