CT27 and CT20B are both known to hit 300
but if you wanna go cheap just take it to 260ish whp
then you can have stock motor, stock ecu, stock fuel system.. that ll save a ton of money
if you want more.. go for a TD06.. even though the spool is quite slow.. the CT20B has insane fast spool up...
i think you should do this if you are happwy with around 260ish whp
CT20B, 3" DP, some kind of free flow intake, upgraded intercooler (greddy, spearco),
consider also
fidenza flywheel, spec clutches stage 2...
