Originally Posted by Wiisdom
Okay I new to this I’m not new to the car game but I’m new to the Mr2 so I have a few questions for now. - The stock motor in the car I believe it’s a 5sfe or some shit, is it iron block or is it aluminum?
- I notice there is a 3sgte that gets swapped in and I have been told all I need to perform this is to get the 2.0 turbo clutch flywheel and pressure plate. Is this accurate?
- Is there anything else needed when you buy the turbo motor basically is it a direct swap?
- Is the stock motor reliable to boost and up to what Psi?
- How does the stock motor hold up to nitrous? Hmm lets say 100 shot
- Okay is the order to take the motor out: axles, cross member, shift linkage, wire harness, mounts?
- Okay If I wanted to get 350whp what would I need 2 do?
- How much can the axles hold? how strong are they
Please if you have some detailed websites pertaining to the MR2 give it to me thanks.
1) 5sfe is iron block.. so is the 3sgte
2) what do you mean to perform?... a better clutch will last longer since the OEM clutch sucks.. flywheel get a fidenza one
3) nope direct swap
4) 3sgte is a good engine and can take a beating.. thats not the problem.. the stock turbo is the problem.. CT26 can be bossted to around 14PSI safely.. but i would just upgrade it to a JDM one (CT20B) or better..
5) niterous.. i heard they can be pretty good.. but i dont know much about it.. search mr2oc.com niterous section
6) i have no clue what your talking about.. just take it out haha
7) 350whp = fuel upgrade (injector, rail, standalone), TD06 turbo or in that range, upgraded intercooler (spearco is my choice), downpipe, exhaust, intake, forged pistons if you want to go the extra mile... other things to consider is .. clutch, flywheel,
8) axles are tough but if you are gonna go beyond 400whp there are custom axles sold by ATS
hope that helped a bit
