Inner tie rod - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-03-2005, 06:05 PM   #1 (permalink)
View SW21's Photo Gallery
2nd Generation Inner tie rod
hi all, i went get my car aligned today, the mechanic told me that i needed to replace my front inner tie rod on the passenger side, my question is , since i am to replace the inner tie rod, what else should i be looking to replace under that area as well? also, should i get oem or aftermarket part as for inner tie rod? thanks in advance.
SW21 is offline   Reply With Quote
Old 11-03-2005, 07:45 PM   #2 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
Doesnt the MR2 lack front inner tie rods? I thought it used the steering rack :/ correct me if im wrong.
Function over form.
Drifting Dane is offline   Reply With Quote
Old 11-03-2005, 08:57 PM   #3 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
No, it has inner tie rods. I had to replace mine a while back as well.
Might as well do the other side as the same time, and check out the outer tie rod ends as well. It's only a matter of time before they go, too. Another thing you might want to check out are the ball joints. They wear out usually around the same time as tie rod ends.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 11-04-2005, 04:50 PM   #4 (permalink)
should i get oem or aftermarket ones? anyone here tries those from ebay?
here is one i am referring to.
http://cgi.ebay.com/ebaymotors/TOYOT...spagenameZWD1V
Old 11-04-2005, 06:18 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997175
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
can't go wrong woth OEM...as far as the Ebay ones,I don't know anyone that has tried/used them .
The Jedi Speeder at CarDomain
Old 11-07-2005, 04:30 PM   #6 (permalink)
4DMR2t's Avatar
On suspension stuff, I'd go oem. Stay away from ebay specials.
