N/A to Turbo - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2005, 05:31 PM   #1 (permalink)
romycha's Avatar
View romycha's Photo Gallery
N/A to Turbo
I'm trying to buy an 2nd gen MR2, and I can only seem to find N/A ones. I have a WRX now, and would like to have a turbo in this too.
Are there any reliable turbo kits for the 5SFE?
Also I am not opposed to building a kit either, so does anyone know where I can get a good manifold also?
Thanks in advance guys.
romycha is offline   Reply With Quote
Old 11-13-2005, 08:12 PM   #2 (permalink)
View Exodeus's Photo Gallery
hey man..i have a 5SFE and i dont even believe it can support a turbo. So if ya want a turbo in an MR2, buy a N/A, then swap the engine for a 3SGTE. I dunno if there is another turbo-able engine out there that can fit into an N/A without many adjustments. But, you will have to get a better tranny and a whole bunch of other stuff, not much of the stock stuff on an N/A can support the power of a turbo. (im not completely sure of anything ive said above, but thats what ive found out so far from my research.)
1991 Mr2 N/A
Exodeus is offline   Reply With Quote
Old 11-13-2005, 09:16 PM   #3 (permalink)
View patR1's Photo Gallery
i heard the 5sfe has a stronger block then the 3sgte, yes u can turbo it, but on low boost
it has been done, some blow some still alive.
but you never be close to a 3sgte
and cost of a clip is roughly the same cost.
http://www.mr2oc.com/showthread.php?...ght=5sfe+turbo
patR1 is offline   Reply With Quote
Old 11-13-2005, 09:30 PM   #4 (permalink)
romycha's Avatar
Since I have posted the thread I have 2 turbo kits.
But I don't know how reliable they are. I have considered swapping in the 3SGTE, but I don't know what's all involved. Can you use the same harness? What about axles? Or ECU?
Old 11-13-2005, 09:41 PM   #5 (permalink)
ur gearbox will fit the 3sgte, but remember its not designed for turbo power, so itl be very fragile, if u want a 3sgte gearbox lsd u have to use turbo axels, hubs as they are more beefier...
u need a 3sgte ecu, unless u run a standalone, body harness is different but you can splice it.
also u neeed to change ur fuel pump.
If u have a half cut turbo u have no problem. As everything is there.
Good read :
http://www.mrtwo.net/mr2modproject/mr2modproject.htm
Old 11-13-2005, 09:46 PM   #6 (permalink)
romycha's Avatar
Well I figured if the gearbox did fit, a clutch would be an immediate fix, and I also figured as much with the fuel, since that is common with most N/A to turbo swaps.
Other than that, is the harness the only thing I have to worry about? What would have to be spliced?
Old 11-15-2005, 03:06 PM   #7 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
if you get this info, I would like to know. I have currently starting piecing together a mr2 starting with a blown 3sgte.
OMNI is offline   Reply With Quote
