How did it go this weekend Jekyl? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2005, 07:26 AM   #1 (permalink)
View Mrwho2's Photo Gallery
I unfortunately missed this even sat. but i would definitly like to know what went on. It would be even better if someone has a video stream.
Mrwho2 is offline   Reply With Quote
Old 11-16-2005, 10:04 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
I'll offer no excuses although I have some
It was pathetically busy at the track so I only had 3 attempts:
Run #1
25.5 psi of boost
1.65 = 60' (missed 2nd)
11.5 @ 123 mph
Run #2
26.8 psi of boost
1.68 = 60' (hit 2nd, but lost all boost and bogged)
11.6 @ 125.75 mph (obviously plenty of power for a 10 second pass).
Run #3
27.8 psi of boost
1.9 = 60' (*see below)
12.4 @ 124 mph
*I'm not sure, but I think I made the error I used to make when I started hitting 1.7s. I think I launched with my hand on the shifter and yanked it out of gear
Some vids:
Huge smokey burnout:
http://www.jekylhyderacing.com/image...agway_2005.mpg
11.5 @ 123:
After talking to NoShoes, we miss communicated (I'm a dumbass) on our throttle pump settings (fuel addded or subtracted on shifts) and I killed those setting on the last run hence the lower mph with more boost.
I was having major 1->2 on all 3 runs.
Even when I got it right it wasn't happy
Somethings to note:
*On run #2 Hyde was idling for well over an hour. We couldn't shut the car off because my dinky battery was having a fit. After an hour+ of idling, doing a burnout, I started a data log. Intake temps in the manifold were 38 degrees C.By 1/2 track they were 28 degrees C and by the finish they were 38C again. I guess the trunk mount works.
*Hyde is currently running the same as he was. Just overheating at the top of the track. He did not flinch running 27.8 psi ... wish I would have done it all year
The year IS done. Hyde is parked for the winter.
I'm going to take a nap ... this year, although awesome, has kicked my ass.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 11-16-2005, 10:06 AM   #3 (permalink)
I love Cin
What's in store for the winter for Hyde:
1. ATS 2.2 stroker with oversized valves. I was hoping we would see 550+ rwhp @ 25-30 psi, but it is my understanding that my fuel system is not going to be able to support that. I may be looking at upgrading the fuel system over the following year. It's not in the budget this time around. The ATS engine should make pwoer 500 or so rpms sooner and spin to 8500 rpms.
2. Some new suspension pieces: Sustec brace for under the front, new strut tower bar up front in combo with my TRD and I hope to have arear bar fabbed that will clear my IC pipes (doubtful). Also hoping to get new struts.
3. SS brake lines, rebuild calipers, maybe new pads and rotors.
4. Find a solution to the constantly breaking rear sway bar tabs.
5. Resolve my IC fan issues. (just a bunch of rewiring).
6. Safety stuff: Harness bar on the roll bar needs to be moved and I may look into having my bar completed into a cage. Maybe doing a full fire suppression system instead of my dinky 2.5 lb extinguisher.
7. 3/4" longer wheel studs.
8. Rebuilding my spare set of axles with ATS CV upgrades to have on hand for backup.
9. New vinyl for some new sponsors
10. Maybe get a bigger front lip and sideskirts to kill some air flo. Anyone got something cheap, used, light and black?
11. Hopefully find a solution to my 275s rubbing the inside of the car.
12. Alignment (it's only been 3 years )
13. Install an external kill switch (ign & alt).
14. Instsall boost gauges that goes to 30 psi.
15. Install new, better roll bar padding from Safe Drives.
I really, really hope that is all ...
Old 11-16-2005, 11:19 AM   #4 (permalink)
MR2 for life
View MarylandMr2's Photo Gallery
i like that back pressure before you took off, it sounded mean
MarylandMr2 is offline   Reply With Quote
Old 11-16-2005, 11:39 AM   #5 (permalink)
I love Cin
Yeah, that's the 2-step rev limiter.
If you look at me 11.1 video here:
http://www.mr2ownersclub.com/mr2records/drag.htm
... it's at night and you can see the flames shooting out from under the car
Old 11-16-2005, 01:41 PM   #6 (permalink)
MR2 for life
whew, thats prob. the meanest sounding mr2 exhaust ive heard. id like to see you run once you bring it back out, your in pa, not to far from where im at.
Old 11-16-2005, 02:12 PM   #7 (permalink)
I love Cin
I have my tenative 2006 race schedule here:
http://www.jekylhyderacing.com/jhracing.htm
Old 11-16-2005, 02:36 PM   #8 (permalink)
View Exodeus's Photo Gallery
oh man, your car is amazing. Ive never seen an mr2 get its front wheels up before!! =D. Great job!!! Is that with a 3SGTE engine or did ya swap?
1991 Mr2 N/A
Exodeus is offline   Reply With Quote
Old 11-16-2005, 02:48 PM   #9 (permalink)
I love Cin
I am not quite getting my front wheels up ... I just yank the front end up real hard
It is the original turbo engine (3SGTE) that came in the car.
Old 11-16-2005, 03:27 PM   #10 (permalink)
View FutureMr2's Photo Gallery
first off car looks real good, and secon im new to the mr2, i have srt4 right now but am getting rid of that for an mr2 and was just wondering if your running stock internals on the 27psi.
FutureMr2 is offline   Reply With Quote
Old 11-16-2005, 08:46 PM   #11 (permalink)
I love Cin
We have an engine being built, so we threw caution to the wind on this last track day.
The engine that is in the car is completely original except for the cams (still original valves and springs).
It has 202,800 original miles on it.
And yes, we ran 27.8 psi on it
Old 11-17-2005, 12:48 AM   #12 (permalink)
andyb16's Avatar
View andyb16's Photo Gallery
Jeff, I'd hate you if you didn't kick so much ass! Miss second and still run 11.5. Jerk.
Congrats on the season and good luck next year. I'm sure it's just gonna keep getting better.
andyb16 is offline   Reply With Quote
Old 11-17-2005, 03:48 AM   #13 (permalink)
View CompanyFlow's Photo Gallery
What were you going up against in your 11 sec. video?
CompanyFlow is offline   Reply With Quote
Old 11-17-2005, 04:53 AM   #14 (permalink)
I love Cin
The video in this thread was against a Celica.
A bunch of people from the Celica forums came out for this event.
