You fill the coolant as much as you can fit in without running the car. Then turn the car on at idle leaving the radiator cap off. While the car runs, it will bubble out all of the air in the lines. Every so often you will have to add some more coolant every couple minutes while the car is running, until it stops bubbling. Coolant will bubble out, it's also pushing air out of the system as well. Usually it takes about 15 minutes to complete the process, you will know it is done when the bubbling stops. When done, just make sure its at a good level and put your cap back on.
