I wouldn't say that it's incredibly difficult. If you haven't done it before yourself it would be a very good idea to get someone more experienced to help you as there are stages where you could really damage either the car or yourself. Take your time and make sure that you keep track of where everything goes as you disassemble it. (I put everything in baggies and label 'em so I don't have to guess later.)
Originally Posted by Nad1370
MK I is a little easier than the MKII.
On the MKII you have to drop the suspension frame to get the trans out. Very diffucult especially if the bolts won't cooperate.
Good luck !
Are you talking about the crossmember? If so, that is not accurate. There is no need to drop the crossmember. The BGB also tells you to drop the exhaust which is not needed if you're very careful about making sure that the engine is supported.
