T3/T4 advice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-11-2005, 08:54 PM   #1 (permalink)
View Mr2SlOw...'s Photo Gallery
Question T3/T4 advice
Ok my plan for my 2 is to drop in a t3/t4 57 trim. My goal is to reach around 350whp. I no I will have to change my fuel pump (supra pump since it fits perfectly and supports it), 550cc injectors, intercooler, adjustable fuel regulator (11.5:1). Also, how much psi can i safely handle with this setup? I also have a K&N FIFK and 3 in turboback exhaust. Does anyone no what i can expect with this set up? I also need advice incase im missing anything.
Mr2SlOw... is offline   Reply With Quote
Old 12-12-2005, 05:09 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Adjustable FPRs do not set your fuel at 11.5:1. They merely set your fuel pressure and ass pressure as you build boost. To get your fuel to 11.5:1, you are going to need something to tune the car with (black boxes or EMS).
350rwhp on 550s is pushing it, but it can be done.
I did it but I was using water injection and race gas.
I would recommend the Walbro pump over the Supra.
How much boost can you run? That depends on how solid your engine is and how well set up your car is. I ran as much as 24 psi on my T3T4 on a stock engine.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 12-12-2005, 07:19 AM   #3 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
i am running a setup similar to what you are looking for..but my t3/t4 is a 50 trim/.63 AR...motor is built bottem end (stock cams) and minor head work....but i'm running 680cc top feed injectors and HKS F-con..i'm with jekly...you will be pushing the limits of the 550s and you definitely need some sort of engine/fuel management...you should look into getting some cams and also an upgrade IC and find a compentent tuner...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 12-12-2005, 12:53 PM   #4 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
He meant adds pressure (at least i hope so)
Function over form.
Drifting Dane is offline   Reply With Quote
Old 12-12-2005, 01:56 PM   #5 (permalink)
What size injectors would u reccommend? I am planning on getting a aftermarket IC. Will I be able to tune it with the help of S-AFC or should i save my money an get it done? I dont plan on using more than 18psi. Would i be able to handle that? my engine is still in good condition with no major problems.
Old 12-12-2005, 02:09 PM   #6 (permalink)
^^save for an EMS if you want some sort of reliabilty....that magical 300rwhp mark on black box tuning is dangerous IMO...you can only trick the stock ECU so much....
91 mr2..07 335i..
