by the way.. this is what im buying... i think its an ok deal.. but im gonna check it out more before i pay.
138,105 miles. Has never been in an accident. carfax attached (see next page)
5 speed manual transmission.
It was fully serviced: 3/15/2005
Timing belt, timing belt idler bearing, timing belt idler, timing belt tensioner, crankshaft gear, water pump, thermostat, thermostat gasket, camshaft seal, oil pump seal, front crankshaft seal, oil pressure sender, knock sensor, a/c belt, alternator, spark plugs, air filter, oil pump housing seal, ported exhaust manifold, ported cylinder head, helicoil all the stripped bolts, coolant flush, boiled radiator, greddy SMIC intercooler, TKO 3" exhaust put on, with new turbo.
new rear tires : 10/27/2005
MOD LIST:
Performance Mods
Upgraded Turbo: GT2540R internally gated at 11psi spring
Upgraded Intercooler: Greddy Side Mount Intercooler
Exhaust: eXtreme Boost 3” Down Pipe
Exhaust: KO Racing 3" Catback
Engine: Ported intake, ported exhaust manifolds, Ported head
Clutch: ACT Stage 3 clutch (less than 9k miles on it, really beefy)
Intake: ATS Throttle Body Inlet
Electronics
Boost Controller: Blitz SBC Spec ID
Greddy EGT and Boost electronic gauges
Apexi Turbo Timer
Suspension
Tokico 5ways adjustable shocks
Intrax springs .5” inch lowering springs
Misc
TRD short shifter
TRD shift knob
RobertsMB
2005 Toyota Corolla XRS
1991 Toyota MR2 Turbo
