92-93 mr2 diference? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-14-2005, 09:54 PM   #1 (permalink)
tamalpro
View tamalpro's Photo Gallery
i have seen several aftermarket parts that say that will fit from a range of years 91 to92 mr2 and 93 till 95 like the spark plug wires, rotors, etc. Can some one tell me the diferences. (im more interested in the mechanical specs) for example i know that the 93 and up comes whit a limited slip diferencial -lsd-
tamalpro is offline   Reply With Quote
Old 12-14-2005, 10:56 PM   #2 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
the 93+ rear suspension is "revised". some people like it better, some people don't like it as much as the older suspension.
the 93+ turbos have larger brakes.
the 93+ front lip is larger (94+ is color matched to the body).
IIRC, the 93+ 5SFE had a knock sensor added to it, along with the square plug wire boots.
94+ had different tail lights and a different rear wing.
that's all i can think of right now.
-Mike
NESW20 is offline   Reply With Quote
Old 12-14-2005, 11:02 PM   #3 (permalink)
View wvturbo2's Photo Gallery
lets see in 91 the steering wheel fails to meet federal standards for crash protection. that was in 91 and 92 then air-conditioning expansion valve could malfunction reducing efficiency.
in 93 ac valve could still malfunction. suspension was upgraded to stffer springs and lengthened trailer arms and synchros in 5 speed were improved. they added wider tires 15 inch square spoke wheels and larger brake rotors and larger throttle body and retuned throttle cam.... If you wanna kno the diff in 94 and 95 just tell me
wvturbo2 is offline   Reply With Quote
Old 12-15-2005, 12:07 AM   #4 (permalink)
tamalpro
rotors
you say they are biger, but the fit is it the same? because on the after market said they only fit 93 and up, so i guess they are rong. Also you said stiffer springs? they alredy are!!! y guess ill be one of those who dont like it, but dont now till i try.
Old 12-15-2005, 12:21 AM   #5 (permalink)
tamalpro
gear box
can some one please explain the limited slip diferencial? i know wat it does but...my 91 mr2 obiously does not have one but i se a PAIR of tire marks on the asphalt, and the two of them start at the same spot. Maybe the lsd can only be noticed on curves, rigth Also can some one tell me the diference betwen the 92-93 gears. Wich gears got shorter or longer, im rebuilding the transmision in 3 or 5 weeks Numbers of the gears would be better.
Old 12-15-2005, 12:59 AM   #6 (permalink)
View Gairloch's Photo Gallery
93+ does not guarantee limited slip, it was still an option.
The head on the 93+ 5sfe's was also designed to breath a little better.
From "howstuffworks.com":
Limited slip differentials use various mechanisms to allow normal differential action when going around turns. When a wheel slips, they allow more torque to be transferred to the non-slipping wheel.
If you want more detail you can find it here: http://auto.howstuffworks.com/differential7.htm
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 12-15-2005, 06:54 AM   #7 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
93's also came with 15'' stock wheels to fit the bigger brakes..
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 12-15-2005, 07:28 AM   #8 (permalink)
View erioshi's Photo Gallery
Specifically the Turbos. I believe that there were brake changes between 91-92 and 93+ NA cars, but I could be wrong. 93+ turbo cars recieved larger brake rotors and bigger brake calipers along with a new master cylinder. Those changes required the 93+ turbo cars to run 15" wheels to clear the brakes.
For the rear suspension, the 93+ cars have revisions to the rear tie rods (toe adjusters), rear cross member, lower control arm bushings and possibly the rear lower control arms. I'm not sure about the spring rates. The suspension was changed because at extreme load and compression, the 91-92 configuration could be pushed into a positive toe situation. The result is that most people will spin the car if a rear corner is overloaded.
That said, I expect that if you ran very stiff springs or coilovers and had the car's suspension properly dialed in, that problem would be minimized on the 91-92 cars. Also in the hands of experienced high-speed drivers (us track junkies) the toe issue seems to be manageable once you have a chance to learn the car's unique behavior. YMMV.
erioshi is offline   Reply With Quote
Old 12-15-2005, 01:50 PM   #9 (permalink)
i have a mag that says that stuff... what i wrote is true... but it doesnt go way in depth so i dont know to much more than that
Old 12-15-2005, 05:02 PM   #10 (permalink)
View 91MR2quickNA's Photo Gallery
Spring rates were changed as well, but I'm not sure of the specs. The 93+'s sit at least 1 inch lower than the 91-92s.
Jason
2005 Tacoma D-Cab 4x4 Off-Road
1991 MR2 w/ ported 1MZFE (MZW20)
1991 MR2 N/A (SW21)
91MR2quickNA is offline   Reply With Quote
Old 12-15-2005, 08:41 PM   #11 (permalink)
tamalpro
wires and gears
can some one tell me the diference?i think the spark wires are diferent (they fit diferent)
Old 12-15-2005, 10:14 PM   #12 (permalink)
^ The valve cover was redesigned in 93. The spark plug wire boots are square instead of circular.
Jason
1991 MR2 N/A (SW21)
