3sgte swap help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2005, 02:53 AM   #1 (permalink)
View drew16's Photo Gallery
Question 3sgte swap help
im planning on swapping a 3sgte into omy n/a 91 mr2, if i buy a swap with engine, tranny,ecu, and all cables, is there anything else i need for the insatllation?
drew16 is offline   Reply With Quote
Old 12-27-2005, 04:32 PM   #2 (permalink)
View Exodeus's Photo Gallery
just get a rear clip, there will be alot of little things that you will need. Plus some of the n/a parts arent strong enough for the 3sgte engine, so just get a clip and be happy..=P
1991 Mr2 N/A
Exodeus is offline   Reply With Quote
Old 12-27-2005, 04:57 PM   #3 (permalink)
View Gairloch's Photo Gallery
Driveshafts, ball joints, control arms, fuel pump to name a few things. You might want to search here and at www.mr2oc.com, this topic has been covered extensively in both places.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 12-27-2005, 05:35 PM   #4 (permalink)
Boosting 15 psi :)
View Drifting Dane's Photo Gallery
wiring harness and axles... i may be leaving some out... i havent thought about it in a while...
Function over form.
Drifting Dane is offline   Reply With Quote
Old 12-27-2005, 06:33 PM   #5 (permalink)
ok just wondering which of the 2 would be better, thanx
Old 01-09-2006, 05:13 PM   #6 (permalink)
sbettencourt's Avatar
View sbettencourt's Photo Gallery
get the rear clip, it will save alot of time and work.
the intake piping and intercooler piping will be the worst, you might have to modify the body harness to fit the 3sgt ecu. (a had to do this when i replaced the 5sfe by the 3sgte in my celica. same engines as in the mr2) you will need axles form a turbo mr2 or you can use the 5sfe trans and axles.
sbettencourt is offline   Reply With Quote
Old 01-10-2006, 11:26 AM   #7 (permalink)
El Capytain
View HighSpeedScene's Photo Gallery
So I take it that the 3sgte engine clip does not include the beefer axles?
HighSpeedScene is offline   Reply With Quote
Old 01-10-2006, 05:07 PM   #8 (permalink)
Boosting 15 psi :)
The clip does include the axles (or at least it should). The clip should have EVERYTHING you need to do the swap, except maybe a new clutch (always a good idea while you have that stuff out and workable).
Function over form.
