Aftermarket Tail Light Housings?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2005, 12:07 PM   #1 (permalink)
View robertsmb's Photo Gallery
Ive been looking to replace my stock tail light housings with aftermarket ones to better fit the paint job Im doing.
I can only find housings for the 94 SW20... and Im thinking that they are the same, but I need to be sure.
Are the 91 and 94 tail lights the same?? Can they be swapped?
RobertsMB
2005 Toyota Corolla XRS
1991 Toyota MR2 Turbo
robertsmb is offline   Reply With Quote
Old 12-28-2005, 12:14 PM   #2 (permalink)
View mr3sgte's Photo Gallery
91 and 94+ tail lights can be swapped but you have to do some modification on the tail light wiring harness and also you have to mody the body where youre gonna fit the center piece...for more info go to mr2oc web site
mr3sgte is offline   Reply With Quote
Old 12-28-2005, 12:50 PM   #3 (permalink)
Thanks.
RobertsMB
Old 12-28-2005, 12:54 PM   #4 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
if you use your old harness...you will have to extend the reverse lights wires...and you will also have to make room for them (in most cars) behind the new center panel...very easy install..should take no more than an hour if you have some sort of mechanical skills.....
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 12-28-2005, 03:21 PM   #5 (permalink)
View thebaudgod's Photo Gallery
There were also some tight looking taillights I saw on ebay... black with two red circles for the lights.... didn't catch a name tho
thebaudgod is offline   Reply With Quote
