fuel pump connections - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-08-2006, 05:01 PM   #1 (permalink)
View vegasvic's Photo Gallery
i just replaced the fuel pump on a '87 mr2 i picked up. stuff has been lying around while i found a new filler hose. i don't remember exactly but, i want to make sure the connections are correct. there are 3 lines coming from the fuel pump. one is threaded (fuel filter), the one just above (longer fuel hose)goes to charcoal cannister, and topmost (shorter fuel hose) goes to metal vertical tube. thanks, vv
vegasvic is offline   Reply With Quote
Old 01-08-2006, 08:46 PM   #2 (permalink)
View Gairloch's Photo Gallery
If you aren't getting the answers you need here you might want to try the Mk I forum on mr2oc.com.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 01-11-2006, 05:10 PM   #3 (permalink)
thanks, will do.
'89 Eng swap, fuel pump? Donald Tercel, Paseo, Starlet, and Sera Forum 15 03-19-2005 05:17 PM
help newbie save '85 with fuel system problem leiniesred MR2 Forum 0 02-28-2005 09:49 PM
Fuel pump requirements for 5psi boost (carb'd 4a-c)? O 16581 72452 5 Archived Corolla threads 4 03-17-2004 12:00 PM
