Rims size.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2006, 06:11 PM   #1 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
View Zero turbo's Photo Gallery
Rims size..
I am planning on putting 15 on front and 17 on back but is this a good idea.Is anyone using the same setup.THX!!!
1-Chuck Norris is the reason why Waldo is hiding
2-When Chuck Norris does a pushup, he isn’t lifting himself up, he’s pushing the Earth down
3-The Guinness World Book of records shows the people that have come the closest to the skills of Chuck Norris.
Zero turbo is offline   Reply With Quote
Old 01-09-2006, 06:26 PM   #2 (permalink)
BahaMR2
numbone's Avatar
View numbone's Photo Gallery
ive never heard of that setup with an MR2 i would think your cornering would be limited and inneficient. but those r only assumptions. are they the same style wheel?
1992 GT-S
numbone is offline   Reply With Quote
Old 01-09-2006, 06:42 PM   #3 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
Yeah
Old 01-09-2006, 10:06 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
it can be done, but to keep the tire heights about the same, you would have to use different height profile tires.I think Doc J&H runs different front and rear on Hyde. be he is all out racing.
The Jedi Speeder at CarDomain
Old 01-09-2006, 11:39 PM   #5 (permalink)
FRANK THE TANK LIVES!
4DMR2t's Avatar
View 4DMR2t's Photo Gallery
Jeff uses 15's up front and 16's in the rear.
I have never seen 2 rims sizes difference from fron to rear. What would be the point? I'm pretty sure Jeff does it to maintain the same amount of rubber in the front as the rear, as the rear wheel well is a bit taller.
If you put 15's on the front, and 17's on the rear, you would need thicker rubber on the front than the rear. That would just be weird.
"It's hard to drive at your limit, but it's harder to know where it is." -Sterling Moss
4DMR2t is offline   Reply With Quote
Old 01-10-2006, 09:56 AM   #6 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
well 15 front and 16 in back will be good?? i just wanted to khow if its better for handling.
Old 01-10-2006, 10:22 AM   #7 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Hyde has 15(f) and 16(r)
Jekyl has 16(f) and 17(r)
My street set up, that is on Jekyl, I originally did because of cost and looks.
I bought Jekyl with 16s all around. When I bought I Hyde I bought four 17s and put them on the rear of both cars and moved the 16s to the front.
17s all around on an MR2 looks silly IMO.
The front looks jacked up.
This is what 16s/17s look like on Jekyl:
http://www.jekylhyderacing.com/images/jekyl_dc.jpg
This is 17s (same rim) all around on one of my old MR2s:
http://www.jekylhyderacing.com/images/bltmg.jpg
http://www.jekylhyderacing.com/image...DragRacing.jpg
http://www.jekylhyderacing.com/image...tocrossing.jpg
The fronts just look to big to me.
Anyway, on Hyde's race set up I based my choice on costs and what TIRES I wanted to run.
More importantly than rim size, you should figure out your tire priorities.
Once you know the tire sizes you want to run, figure out the rim size for them, THEN look at styles.
I would never stagger more than 2" front to back.
I think you are asking for way too much difference in sidewall behavior.
Just my 2 psi.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 01-10-2006, 10:32 AM   #8 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
your car will look like a top fuel dragster with 15s up front and 17s in the rear...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Painting Rims --- Step by Step Peter Show & Share 32 07-25-2005 10:02 AM
