Valve Cover Gaskett Help PLZ!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2006, 12:07 PM   #1 (permalink)
View robertsmb's Photo Gallery
Ok, my MR2 is in the shop for an oil leak and they said the leak was around the Valve Cover Gasket.... the shop has called every parts store including Toyota, and they cant find a Vavle Cover Gasket for a 2.0L DOHC Turbo MR2... they cant even get a part number for it.. like it doesnt exist....
Can someone please help me? I woudl like to get this gasket as soon as possible to get my engine running right.
RobertsMB
2005 Toyota Corolla XRS
1991 Toyota MR2 Turbo
robertsmb is offline   Reply With Quote
Old 01-10-2006, 04:34 PM   #2 (permalink)
View Gairloch's Photo Gallery
You might want to call the stealership yourself. I question how hard they tried.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 01-10-2006, 07:10 PM   #3 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
go in to the dealership, talk to their parts department. don't let them tell you no. it's in their parts catalog (on the computer). the CAN get it for you.
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 01-10-2006, 08:30 PM   #4 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
dealers have them or can order them..can't remember what i paid for it..wasn't a whole lot.. just make sure they order both of the peices. outer edge and the 2 circle things that go around the 2 center spark plug holes
The Jedi Speeder at CarDomain
Old 01-12-2006, 08:55 AM   #5 (permalink)
View OEMonkey's Photo Gallery
11213-88381: Valve Cover Gasket
11214-88381: Valve Cover Gasket
90210-07001: Valve Cover Washer(for the bolts)
Two PN's for the VC gaskets bec. there are 2 peices.
OEMonkey is offline   Reply With Quote
Old 01-12-2006, 05:10 PM   #6 (permalink)
"The Mighty Gen3"
MR. 2Lanes's Avatar
View MR. 2Lanes's Photo Gallery
Same thing with my car. And I can literally see oil spitting out of my valve cover onto my turbo. Shit sucks! Any whoo, is it pretty hard to replace if anybody has done it themselves before? I'm gonna save money and fix myself. It doesn't seem that it would be that difficult, but I know the bolts are going to be a bitch to get off.
Keep It Boostin MRtunians!!!
MR. 2Lanes is offline   Reply With Quote
Old 01-12-2006, 05:27 PM   #7 (permalink)
The mechanics and eveyrthing else I have heard says its easy.. like a 1 hour job...
Take off the throttle body and then the valve cover... the gaskett is right underneath... clean the shit out of the cover and seat the gasket and put it back together...
end of story.
RobertsMB
Old 01-12-2006, 07:59 PM   #8 (permalink)
MR2-Good-4-u's Avatar
View MR2-Good-4-u's Photo Gallery
mine has the same problem but the 2006 edition of sport compact car had a write up about the mr2 and they said it could be the phillips head bolts that they used, they said they work themselves loose all the time and you should replace them with hex head which you can get at twos r us.
MR2-Good-4-u is offline   Reply With Quote
Old 01-12-2006, 08:15 PM   #9 (permalink)
Gameroom cash: $253010
View BDSL's Photo Gallery
The valve cover gasket is more than an hour job. I have done it in my garage and from start to finish takes about 2-3 hours.
Remove rear strut tower bar.
Remove intercooler pipings.
Remove throttle body inlet.
Swing the trottle body out of the way. You might want to remove a bunch of the electrical connectors and hoses so they don't get in the way.
Remove the EGR pipe.
Remove the spark plug wires.
Then you should have complete access to the valve cover.
BDSL is offline   Reply With Quote
Old 01-12-2006, 09:57 PM   #10 (permalink)
"The Mighty Gen3"
MR. 2Lanes's Avatar
Alright!!! Thanks for the estimated times!!!
I'll be sure to get it done now. Thanks again!!!
Old 01-25-2006, 12:01 AM   #11 (permalink)
"The Mighty Gen3"
MR. 2Lanes's Avatar
Holy crap!!! It took me 4 hours to do this job. Had to replace valve cover gasket and twos r us hex bolts, and clean turbo of oil from the valve cover sputtering oil all over. Now the turbo doesn't lag in 4th and 5th gear. Woohoo!!! Thanks for all the help guys!!!
How-To Guide: Removing and Painting a Valve Cover - 5SFE -- 56K warned Lots of Pics RedPhoenix 3rd & 4th Generation (1992–1996 & 1997–2001) 72 02-14-2011 09:17 PM
PCV valve is screwed up... I helped it.. 4EVERCooL 1st Generation (1995-1999) 3 11-14-2005 07:55 PM
Removing Gen 2 Valve cover? PoR2GeEzCamry 1st & 2nd Generation (1983–1986 & 1987-1991) 3 03-20-2005 10:53 PM
Valve Cover Estimate ArmyofOne Camry & Solara Lounge 5 10-02-2004 10:15 PM
