still hitting that rev limiter
J&H thanks for the info about that code 52. i put the new knock sensor in and the car is boosting 16psi now. but im still hitting some kind of limiter when the car gets to around 5200. it doesnt feel like fuel cut because i have the fcd on setting 7 and i think eliminates the fuel cut. the car idles at 500 rom. but when it gets to 5200 it sounds likes its at a higher rev than that but im not sure. the car is running great besides that. could it possibly be the coil that is goin bad and if so how much is a coil to replace. the ignition is in great shape now that i put in the new distributor and plugs cap and rotor. any one experience this problem im having.
does the hks fcd setting 7 raise fuel cut to 17 or does it eliminate it because i heard setting 9 on the fcd raises it to 17 so im confused now.
If it's cheap and fast, it's not reliable
If it's reliable and cheap, it's not fast
If it's fast and reliable, it's not cheap
VTEC: All the lag, none of the turbo. It's like waiting for bad sex! ...
