Power Steering problem.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2006, 07:24 AM   #1 (permalink)
Wazzuup!
MR2crazybyong's Avatar
View MR2crazybyong's Photo Gallery
Hi guys!!
i've got a problem on my power steering. months ago(before my accident) the P/S warning light on the dash would sometimes light up and i would sundenly the steering becomes hard.. no more power steering! then il shut the engine off and then start it again, power stering is back to normal! so i didnt mind to much then.. but now its always on and the P/S is not functioning.. what could be the problem?? my mechanic checked it and think its the P/S computer box that is screwd up.. could this be? thanks in advance for your help guys..
www.cardomain.com/id/mr2crazybyong
YM id: mr2crazybyong
MR2crazybyong is offline   Reply With Quote
Old 01-16-2006, 12:07 AM   #2 (permalink)
View Mr2SlOw...'s Photo Gallery
USA
You should just get rid of it all together!! PS sucks !!
Mr2SlOw... is offline   Reply With Quote
Old 01-16-2006, 06:45 PM   #3 (permalink)
BahaMR2
numbone's Avatar
View numbone's Photo Gallery
sounds like your power steering computer. i had similar symptoms. all i did was unplug the power steering computer harness and wait a minute then replug it and it has werked ever since (8 months). if youve tried this i guess yer going to have to see what the other users might suggest.
1992 GT-S
numbone is offline   Reply With Quote
Old 01-16-2006, 07:00 PM   #4 (permalink)
jdm 2nd gen ftw!
View nepopolus's Photo Gallery
eh no idea evey car ive had i either ripped it out or it never came with it, i am used to it now i like the response you get alot more :P and you get a work out when you drive
nepopolus is offline   Reply With Quote
Old 01-17-2006, 10:33 AM   #5 (permalink)
Wazzuup!
well i replaced the computer with a working one from another mr2, still it didnt worked.. could it be the pump? il check the wirings..
Old 01-17-2006, 05:54 PM   #6 (permalink)
View Gairloch's Photo Gallery
Sounds like you're on the right path.
Just so ya know; if you disable your power steering that causes your steering to get mushier not tighter. It's still a hydraulic system whether you're using the power assist or not.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 01-17-2006, 06:02 PM   #7 (permalink)
Rockin the STi
View onehotcamry's Photo Gallery
yeah gairloch's right. You have to actually swap it all out to a non power steering unit if you want a true car w/o power steering.
It's actually harder to drive/turn a car with it just disabled than it is on a car w/o power steering.
04 WRB STi - Stg. 2
93 White Mr2T - 263 rwhp @ 10psi
95 Black Mr2T - TKO exhaust
04 Suzuki GSX-R600
onehotcamry is offline   Reply With Quote
Old 01-17-2006, 09:05 PM   #8 (permalink)
L J
L J's Avatar
View L J's Photo Gallery
there was actually a trick to get the power steering back... this is a common problem from what i hear... all you have to do is put the key in the ignition and turn it from the off to on position 14 times without starting the car or cranking it... just the on position... this method works for me just fine... my p/s usually goes out once a year and this quickly fixes it...
L J is offline   Reply With Quote
Old 01-18-2006, 10:11 AM   #9 (permalink)
Wazzuup!
is this true? well i guess there's nothing to lose in trying..
Old 01-19-2006, 02:28 AM   #10 (permalink)
I've heard it before too, just forgot about it. I don't have PS
Old 01-21-2006, 02:22 PM   #11 (permalink)
View semi-charmed's Photo Gallery
i had the same problem...P/S light went on one night and i lost power steering...got home and turned the iginition off and on (to the third position, not crank) 14 times and problem solved...quite odd....
-Ryan
Project Turbo Two
semi-charmed is offline   Reply With Quote
Old 01-21-2006, 05:10 PM   #12 (permalink)
Rockin the STi
that's only a temporary fix though. It'll come back eventually.
04 WRB STi - Stg. 2
04 Suzuki GSX-R600
Old 01-22-2006, 10:45 AM   #13 (permalink)
Wazzuup!
dumb stupid mechanics! theyve been looking for the cause of the problem for a week! then i got tired and brought the car home to fix it myself.. it didnt take me 5 minutes to spot where the problem was.. it was just a faulty connector for the power steering pump!
Old 01-22-2006, 08:22 PM   #14 (permalink)
what i don't understand is...why is it that turning the iginition off and on 14 solves the problem?...i'm assuming it resets some relay or computer or something...and why is it only temporary?...what causes the problem in the first place?
I, for one, am not paying for anything if this simple fix solves the problem...even if it is for just 8 months at a time...
-Ryan
Project Turbo Two
how to disable power steering pump? nadir Celica Forum 14 03-07-2009 07:05 AM
Lexus IS Pricing (Canada) lexusis350 Toyota News 28 10-01-2007 11:30 AM
Avalon problems with power steering Jaggrey 1st Generation (1995-1999) 11 05-15-2006 01:58 PM
power steering belt removal and crank pulley Q's CrawlingEye Camry & Solara Lounge 1 06-28-2005 04:51 PM
power steering problem 90camryV6 Camry & Solara Lounge 3 07-11-2003 10:47 AM
