What turbo that makes 300+ at only 9 psi can be run at only 9 psi?!
The least amount of boost I could run on my T3T4 and my GT35R was 13 psi (even with an 11 psi spring).
I assume you are using a pretty big turbo since you are hitting 200 rwtq so late.
Your A/F looks great
What are you tuning with?
Looks like you are using the stock cams - correct?
I suspect revving all the way to 8500 rpms sounds nice
My new engine will rev that high, but I think shifting accurately above 7500 rpms will be a chore.
