Another Electrical Question.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-16-2006, 04:36 PM   #1 (permalink)
View GteFreak's Photo Gallery
My car will start for a couple of times and then not start at all, I tested the alternator 3 times at adworkvance auto and auto-zone it passed all 3 times, i checked all my grounds and there good, ive checked for any loose wires and found none, when i disconnect the battery when the car is running it dies.....the battery is brand new.....what am i missing!!! the battery is now reading 11 volts....
motor:95 jdm 3s-gte, the car was a N/A before....it ran good for almost a year.
any suggestions?
GteFreak is offline   Reply With Quote
Old 01-16-2006, 05:35 PM   #2 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
when it doesn't start, what kind of no-start is it? cranks but doesn't fire? doesn't crank? tries to crank? half-fires but doesn't quite make it? clicks once? clicks repeatedly? cranks really slowly? cranks really fast?
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 01-16-2006, 05:52 PM   #3 (permalink)
Turns over half way then clicks a couple of times....
Old 01-16-2006, 05:57 PM   #4 (permalink)
N00B ;)
Rexinre's Avatar
View Rexinre's Photo Gallery
ELD??? Fuses? Grounds?
What kind of battery is it? Where did you get it?
Did you take the alternator out to test it?
Rexinre is offline   Reply With Quote
Old 01-16-2006, 06:05 PM   #5 (permalink)
Yes I did all that....It's in my post...Except for the ELD...what is that?
Old 01-16-2006, 07:16 PM   #6 (permalink)
Please guys, I need help...I'm stumped. Ant body know where I can find the answer?
Old 01-16-2006, 07:32 PM   #7 (permalink)
1 FST MR2 430 WHP @19 PSI
turbonatormr2's Avatar
View turbonatormr2's Photo Gallery
It could be your starter or the seloniod that sits on the starter
turbonatormr2 is offline   Reply With Quote
Old 01-16-2006, 07:38 PM   #8 (permalink)
3SGTE & 1GRFE
hmm, sounds like it might be your starter solenoid. if the hold-in winding isn't functioning, that would explain the half-crank and clicking.
have your starter and solenoid tested (might as well check them both since they're attached).
-Mike
Old 01-16-2006, 09:27 PM   #9 (permalink)
N/A bites
Tercel GTS's Avatar
Your post never says that you tried another battery nor that you had the battery tested. 11volts is too low. Did you have the alternator tested while it was on the car or off?
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 01-16-2006, 09:44 PM   #10 (permalink)
3SGTE & 1GRFE
ooh, Tercel is completely right. i missed the part about the battery voltage. try a known good battery and see what happens. if you get the same thing with a GOOD battery, then proceed to check the starter and solenoid.
-Mike
Old 01-16-2006, 10:12 PM   #11 (permalink)
I got the alternator tested off the car....I found a short a few minutes ago....My freind's brother is a master tech for toyota of orlando he taught me how to check for bad grounds and shorts. This is what I did.
Make sure everything on the car is off
disconnect the negative battery cable ONLY.
Connect the gator clamp of the tester to the negative battery terminal
Now make contact with the pointed part of the tester to the negative battery cable
If the light comes on bright you have a short
have a freind hold it for you in place and start pulling fuses one by one until the tester turns off
In my case when i pulled the dome light fuse the tester shut off....that was my short
Hope this helps others....
Old 01-17-2006, 02:09 AM   #12 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
11 volts is too low. maybe a dead cell. but with 11 volts, car will not function properly..a good battery will read 12.5-13.5 or even a little higher.
The Jedi Speeder at CarDomain
Old 01-17-2006, 02:46 AM   #13 (permalink)
View todd0305's Photo Gallery
I had the same problem not with my 2 but another car and turned out to be the starter.
todd0305 is offline   Reply With Quote
Old 01-17-2006, 08:53 AM   #14 (permalink)
N00B ;)
Rexinre's Avatar
So it turned out to be a bad ground that you claim you already checked stated in your first post?
Glad you found the problem!
Old 01-17-2006, 11:52 AM   #15 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
great tip!
Electrical Question..... Mr2SlOw... MR2 Forum 9 01-18-2006 01:12 AM
Help with electrical question Please gtech MR2 Forum 4 10-09-2004 09:16 AM
Electrical component cleaning question brink Hardcore Tech and Competition 4 11-07-2003 07:07 PM
HELP: Question on taillight indicator & other Electrical Problems!!! thisdj78 Camry & Solara Lounge 7 08-11-2003 11:31 AM
Electrical question........... Twincam16 Hardcore Tech and Competition 4 01-15-2003 12:18 AM
