2000 spyder 5sp exsesive oil loss? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2006, 12:40 PM   #1 (permalink)
View metmacfab's Photo Gallery
Question 2000 spyder 5sp exsesive oil loss?
2000 Spyder 5sp has extreme oil loss. not external. no smoke and no soot inside tailpipe.
changed to synthetic oil at 70,001 miles used 2 qts in 6 months, another 3 qts. in 4 months. oil is the best there is, so its not the oil. any thoughts?
metmacfab is offline   Reply With Quote
Old 01-25-2006, 01:11 PM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
It's the oil. Synthetic oil on older engine.
It went through combustion chamber little bit at a time. You might not notice the smoke.
93 ST185
ST185 is offline   Reply With Quote
Old 01-25-2006, 03:50 PM   #3 (permalink)
View CompanyFlow's Photo Gallery
It might be the best there is at lubricating, but certainly wasnt made for sealing.
CompanyFlow is offline   Reply With Quote
Old 01-26-2006, 01:25 PM   #4 (permalink)
I read in another Toyota forum that when the pre cats go bad it overhaets the oil and causes a oil loss. Any body else had this hapen? or know of a pre cat ckeck procedure?
Old 01-26-2006, 03:20 PM   #5 (permalink)
Noob :-)
Link me to that thread.
If your cat is clogged, you will feel power loss.
And I've never heard that it can overheat the oil.
93 ST185
Old 01-27-2006, 02:35 PM   #6 (permalink)
View keck03's Photo Gallery
precat failure is common on 2000-2001 spyders. oil loss is the first sign the engine is on its way out. i would def get it checked out.
http://www.spyderchat.com/phpBB/viewtopic.php?t=8449
so common they even started a list of engine failures.
http://www.spyderchat.com/phpBB/viewtopic.php?t=46
keck03 is offline   Reply With Quote
Old 01-27-2006, 05:50 PM   #7 (permalink)
Noob :-)
Thanks for the links keck03.
I stand correct. If your precat failed, you will definitely feel power loss.
It will not "heat the oil". It may cause oil loss but not by heating it up.
If I were you, and have oil loss after changing to synthetic, I would switch back.
93 ST185
Finally Fixed the Oil Leak A2brb Camry & Solara Lounge 15 02-07-2006 07:42 AM
How many qts of oil for my 2000 camry? persianKID 3rd & 4th Generation (1992–1996 & 1997–2001) 4 04-24-2004 09:41 PM
Camry 2000 oil recommended carlosalfaro 3rd & 4th Generation (1992–1996 & 1997–2001) 8 12-19-2003 09:32 AM
Build up under oil cap.... 2000 LE V6 w/ 85kmiles 2000CamryLEV6 3rd & 4th Generation (1992–1996 & 1997–2001) 4 09-15-2003 09:40 AM
