gen3 motor mr2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2006, 03:38 PM   #1 (permalink)
MAX BOOST!!!!!!!
View mr2_dori's Photo Gallery
2nd Generation gen3 motor mr2
i have a gen3 3sgte. i have a tanabe downpipe, hks cam gears, hks headgasket, apexi intake, tko exhaust, boost controller. what is the potential of this engine that i have right now. how much hp and all that good stuff.
mr2_dori is offline   Reply With Quote
Old 01-29-2006, 11:30 AM   #2 (permalink)
MAX BOOST!!!!!!!
anybody help please.
Old 01-29-2006, 04:01 PM   #3 (permalink)
Ontario's King of AW11
View yellow86MR2's Photo Gallery
how much boost are you running?
yellow86MR2 is offline   Reply With Quote
Old 01-30-2006, 01:03 PM   #4 (permalink)
MAX BOOST!!!!!!!
well stock right now. but up to 18psi
Old 01-30-2006, 02:22 PM   #5 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
The potential of the engine is anywhere from 200 - 800whp... I guess it just depends on how much you want to spend.
With your current mods at stock boost.... I would GUESS (guess is used very strongly here) that you are around 220whp.
Old 01-31-2006, 08:08 AM   #6 (permalink)
View iowamr2's Photo Gallery
2nd Generation
sorry but i think that guess of 220whp is a little on the low side. the 3rd gen 3sgte had 245 at the crank stock. it does also depend on if you got the 3rd gen ECU also, as im sure there was a little bit of remapping done to compensate for the larger turbo, so if you are still using your stock ecu then the numbers will be down a bit. however with the much more free flowing exhaust system i would say your closer to around 240whp roughly. on the other side though, your cams might be hurting your bottom end.
iowamr2 is offline   Reply With Quote
Gen2 3sfe (USDM) vs. Gen3 3sfe (JDM) - What's the Difference? airswoosh1 1st & 2nd Generation (1983–1986 & 1987-1991) 15 12-24-2005 12:10 PM
Gen3 T emissions!! HELP!!!!! TeamTRJ MR2 Forum 1 10-13-2004 02:27 PM
3SGTE Gen2 or 3SGTE Gen3 victor91mr2 MR2 Forum 22 06-04-2004 12:40 PM
