Massive Oil Leak Need Help!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-06-2006, 01:52 PM   #1 (permalink)
'88ROLLAGTS's Avatar
View '88ROLLAGTS's Photo Gallery
Gen1 Massive Oil Leak Need Help!!
i need some help locating a oil leak that seems to be getting worse every day. it is a '86 mk1 mr2. i had to remove the air conditioning compressor to even see the back side of the motor. i thought i had it fixed when i removed a oil filter (toyota brand) that wouldn't tighten down all the way, but it is still there and worse than ever! i was told that it could be the gasket that is between the oil filter mounting bracket and the motor (not sure exactly what its called). i cant see where any oil is coming from though to be sure. i also checked out the "oil pressure sending unit" but couldn't see any oil or even a way to remove it to replace that gasket. i have also looked at the underside of the distributor but still see nothing. i could really use the help, i really dont want to kill another 4age! this seems to happen to all my drivers
'88ROLLAGTS is offline   Reply With Quote
Old 02-06-2006, 03:35 PM   #2 (permalink)
View Gairloch's Photo Gallery
Is it just not leaving marks on the motor or has the motor got so much gunk on it that you can't tell new from old?
If it's the latter I would get in there with a degreaser and a rag and go to town.
I wouldn't start replacing gaskets until you identify where the leak is coming from. You could end up rebuilding the motor :p
Do you have any indication at all of where the leak is coming from? Even what side of the engine bay?
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 02-06-2006, 04:06 PM   #3 (permalink)
BRAKE/STEER/THROTTLE
ToyotaTechGeek's Avatar
View ToyotaTechGeek's Photo Gallery
i would check the two 'o' rings on the oil filter sandwich adaptor, then there are several crush washers on the oil cooler lines (does your car have the oil cooler?) and then i would check the dizzy 'o' ring and perhaps inside of the dizzy itself for oil leakage inside. after all of that, i would do a valve cover gasket set just to round it all out.
ToyotaTechGeek is offline   Reply With Quote
Old 02-06-2006, 05:28 PM   #4 (permalink)
i think its coming from around/below the distributor. i was told it was the the "oil filter sandwich adaptor" and it would be devastating to loose pressure while driving. it is definatly coming from the exh. side of the motor. the car does have the oil cooler that is a part of the radiator line in the engine compartment. i have got under it a couple of times once while running but i couldn't see any leaking oil (even with the a/c compressor off) but every morning when i leave for work i see a huge puddle of oil. i have also reached behind the motor to check for fresh oil after it has sat and after it has ran but i dont see/feel any fresh oil under the distributor or valve covers, what does it take to replace the sandwich adapt.? can it be done in a afternoon??
Old 02-06-2006, 06:02 PM   #5 (permalink)
yes. it's two 'o' rings and perhaps the two copper crush washers.
oil leak! help! matrix37495 Tercel, Paseo, Starlet, and Sera Forum 7 05-28-2005 10:49 PM
Oil leak problem Robbo Supra Forum 5 05-23-2005 06:48 AM
Oil Leak possibilities jsandek Camry & Solara Lounge 7 02-28-2005 01:29 PM
Massive Oil Leak..possibly front main seal EMMETT03 Camry & Solara Lounge 4 12-06-2004 08:46 PM
Aggonizing oil leak! IMPORTMyth01 MR2 Forum 1 08-26-2004 11:29 PM
