colder weather lower boost? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2006, 08:05 PM   #1 (permalink)
View carcatz's Photo Gallery
do you guy have lower boost in colder weather?
carcatz is offline   Reply With Quote
Old 02-09-2006, 08:22 PM   #2 (permalink)
Gameroom cash: $253010
iTrader Score: 6 reviews
View BDSL's Photo Gallery
Depends...
I think most people do it because they are afraid of running too lean (not enough fuel). Air is denser in cold temperature. Your fuel system or other components might not able to handle the extra air.
BDSL is offline   Reply With Quote
Old 02-09-2006, 09:18 PM   #3 (permalink)
my car is stock, dose this happen to stock vehicles?
Old 02-09-2006, 09:59 PM   #4 (permalink)
View wingmanlg's Photo Gallery
when its cold out you may run a little more boost because air is denser and therefore more air gets in so yes this happens to all vehicles....
wingmanlg is offline   Reply With Quote
Old 02-09-2006, 10:23 PM   #5 (permalink)
Wazzuup!
MR2crazybyong's Avatar
View MR2crazybyong's Photo Gallery
yup! so in cold weather you should have a little higher boost than in warm weather with the same boost settings.
www.cardomain.com/id/mr2crazybyong
YM id: mr2crazybyong
MR2crazybyong is offline   Reply With Quote
Old 02-09-2006, 10:27 PM   #6 (permalink)
If your car is stock, there is no worries. You T-VSV will automatically switch to limp mode.
You can't lower your boost level below your stock setting unless you change the wastegate spring.
Old 02-10-2006, 07:00 AM   #7 (permalink)
well here is my problem....my after market gauge is showing about 1psi and my factory gauge just about pegs at the +...I can still hear my bypass valve working and feel some boost..I've tested the gauge with a compressor fro the manifold and it reads fine...I have had 10psi this summer thats why I was wondering why the cold might have something to do with it?
Old 02-10-2006, 09:45 AM   #8 (permalink)
10 psi on stock CT26 in cold weather is fine provided your car is maintained properly.
Old 02-10-2006, 01:45 PM   #9 (permalink)
I think your missing what i'm saying I only get 1lbs of boost in the cold weather..I just changed my plugs,cap,rotor, wires..thought that would do it but nothing..do you think that the cold air intake has something to do with it?
Old 02-10-2006, 03:27 PM   #10 (permalink)
Check for leak in the air plumbing (between the turbo and the intake manifold). You have an air leak.
Old 02-10-2006, 08:00 PM   #11 (permalink)
I'll give it a check thanks
Old 02-12-2006, 06:10 PM   #12 (permalink)
checked all hoses, if I remember correctly this happened last winter, I was just wondering if this happens to other mr2s. if not dose anyone have any suggestions??
Old 02-22-2006, 12:48 PM   #13 (permalink)
View arg0naut's Photo Gallery
Somewhat related:
I went to Lake Tahoe this weekend, and on the way up I noticed my blow-off valve wasn't well... blowing off. I know I was boosting, the crap stock boost gauge was at the + and I was over 4000 rpms. But when I went to shift, no blow-off. Fairly cold weather, snow on the ground, going uphill.
Worried something is wrong with the turbo.... =/ orrr maybe because of cold weather? but from what you guys were talking about, cold weather shouldn't affect the boost that much?
arg0naut is offline   Reply With Quote
Old 02-22-2006, 02:57 PM   #14 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
If you are making boost and not blowing off, that sounds like a problem with the BOV, not the turbo.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 02-22-2006, 03:49 PM   #15 (permalink)
aka "Downforce"
View Strat42586's Photo Gallery
I had a SARD BOV for a while, but in the cold it would stick and not open smoothly until it was completely warmed up. It caused turbo surge, so I got rid of it. I think that's your problem arg0naut.
As for the original question, you got might have a leak in your boost gauge somewhere, if you are still feeling the same power, but your gauge isn't reading right.
Strat42586 is offline   Reply With Quote
I Finally Got My Boost Controller Working pituala Supra Forum 2 11-08-2004 03:04 PM
fuel cut and max boost MR2Jedi MR2 Forum 13 11-04-2004 09:43 AM
Loss of boost pressure after induction service on '91 turbo PapaBobDole MR2 Forum 1 10-26-2004 09:24 PM
choking/bucking under boost rony MR2 Forum 5 09-10-2004 12:49 AM
about lower springs Candiman Camry & Solara Lounge 14 04-06-2003 12:44 AM
