timing belt frustration! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2006, 11:12 PM   #1 (permalink)
View jesse0880's Photo Gallery
i spent a few hours tring to install my new timing belt and im having a big problem with the crank lining up with the cams. I'll set the crank on TDC and line up the cams on the specified marks. as soon as i pull the pin out of the tentioner, the belt tightens, the crank stays put, but the cams retard about a tooth or two. i tried setting the cams advance then pulling the pin but they still wont line up. anyone got any pionters on lining every thing up.
jesse0880 is offline   Reply With Quote
Old 02-15-2006, 02:23 AM   #2 (permalink)
OMNI's Avatar
View OMNI's Photo Gallery
hello
use the black wide paperclips with the shiny handles to hold the belt on the cam sprokets. try aligning the marks up and leaving most of the belt slack in the tensioner area. keep trying though, you will get it.
hoi hoi
OMNI is offline   Reply With Quote
Old 02-15-2006, 12:32 PM   #3 (permalink)
View Gairloch's Photo Gallery
I use a zip tie.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 02-15-2006, 04:56 PM   #4 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
make sure you get ALL of the slack out of the belt before you pull the pin on the tensioner.
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 02-15-2006, 11:35 PM   #5 (permalink)
FINALLY! i finally got the motor to line up. i put a c-clamp on the exhuast cam gear while i did the tentioner. now i just gotta put all that shit back on the motor.
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
Timing Belt work mandyfig Camry & Solara Lounge 1 02-07-2005 08:35 AM
