You might want to back them all the way out then tighten them down again. Inspect the shield under the bolts and make sure that it hasn't rusted out under the bolts so they aren't holding anything. It would be a good idea to use some blue lok-tite on 'em when you put 'em back in. They can get rusted up pretty badly.
If the bolt holes in the heat shield have been expanded by rust you could put a washer on the bolt big enough to cover the expanded hole.
If one or more of the bolts fights you when you try to take it out, soak it down in PB Blaster or whichever penetrating oil you use and try again later, don't try and force it. Those bolts have been through a million heat cycles and if they're really stuck they can be brittle enough to actually break off.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
