yeah definately make sure you keep your old motor for parts if you buya celica, camry one you will most likely need to switch out intake manifold, exhaust manifold, metal coolant lines, water housing < dont know correct term but it sits on left side of the head, fuel rail, fuel line that runs from fuel rail, motor mounts, i think thats it
hope this helps you out a little bit so your motor doesent end up like mine. Ive got a celica 5sfe and we found out after we had the motor trans in that we had to switch out more stuff wut a mess
