Shifting into 1st gives me 3rd gear ??
Last night I picked up a Black 91 MR2 turbo. 205k miles! Sweet deal.
1st gear is messed up. When you shift into first it is actually third. No way to get into 1st. Does not grind or anything, it goes right in as if you were in 1st but it is third. All other gears work fine. Any ideas?
Maybe this is just a linkage issue?
Also the key only works the ignition, not the doors trunk or T-tops. Can I get a door key from Toyota? Ingition must have been changed out.
Thanks ! Glad to join the Mr2 crew.
-Bob
