wtf is the problem? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2006, 05:21 PM   #1 (permalink)
View silentmr2turbo's Photo Gallery
wtf is the problem?
ok i was driving my car and for probably like 30 min then i was driving in 4th and just i feel my rpms go down then i stop at the stop light thinking nothing of it then i start in first and i prolly get to about 4k rpm's and it drops back down and kept doing that the only way i could drive it is if i shifted at like 2k and dident give it barly any gas
silentmr2turbo is offline   Reply With Quote
Old 02-22-2006, 05:23 PM   #2 (permalink)
any 1 got any sugestions?
Old 02-22-2006, 05:33 PM   #3 (permalink)
mr2rider91's Avatar
View mr2rider91's Photo Gallery
kinda rare but it could be a clogged cat
or maby fuel filter
mr2rider91 is offline   Reply With Quote
Old 02-22-2006, 08:09 PM   #4 (permalink)
yea its really wierd and it only happens when i slam on the gas so is that what u think it could be?
Old 02-22-2006, 08:37 PM   #5 (permalink)
mr2rider91's Avatar
ya i would try a fuel filter
Old 02-22-2006, 08:54 PM   #6 (permalink)
yea ill look into it thanks
Old 02-22-2006, 10:13 PM   #7 (permalink)
El Capytain
View HighSpeedScene's Photo Gallery
If it only happens when you mash the gas, the problem is most likely fuel related. I agree, look into the fuel filter first as that would be the cheepest/easiest thing to replace.
HighSpeedScene is offline   Reply With Quote
Old 02-23-2006, 11:16 AM   #8 (permalink)
View thetailwind's Photo Gallery
I had this problem when I first got my car. When you floor it... It boggs! Does the sound of the car drop pitch and rattle a little? If so, start with spark plugs(replace them if they have considerable mileage also check the gap) and then check distributer cap for debris or just replace it. It could very well be the fuel filer which is more than fun to change! Good luck
thetailwind is offline   Reply With Quote
Old 02-23-2006, 11:31 AM   #9 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
sounds like an exhaust leak..what year is your car??...i'm guessing its a turbo??...
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 02-24-2006, 03:00 AM   #10 (permalink)
no it was the fuel cut shit man i wanna find the safest way to fix it should i plug the vaccume lines?
Old 02-24-2006, 08:12 AM   #11 (permalink)
get a fuel cut defender...you can buy one..or make one yourself...
91 mr2..07 335i..
Old 02-27-2006, 06:05 PM   #12 (permalink)
tamalpro
View tamalpro's Photo Gallery
same problem wem new
i got the exact same problem wen new, the batery cables were dirty and loose, then again with the vacum lines, and then again with the MAF cable was loose, in all 3 ocations , my engine behaive just like yours, good luck
tamalpro is offline   Reply With Quote
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
2005 Corolla LE dashboard/door alignment problem richs Archived Corolla threads 8 09-21-2005 04:02 PM
94 corolla electrical problem al_sniperrolla Archived Corolla threads 0 10-16-2004 10:42 AM
WTF? Trans problem? 87Camry5Speed Camry & Solara Lounge 0 08-02-2004 10:02 PM
WTF=what the fuk?? markham/richmond hill bondobondo Feedback: Buyers, Sellers, and Vendors 36 08-22-2002 07:49 PM
