What drives engine temp guage? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2006, 04:51 PM   #1 (permalink)
View xmacdaddy's Photo Gallery
Is the engine temp guage on the dash driven by the Radiator water temp sensor? Or is there another temp sensor on the actual engine?
My temp guage is out.
Also, are the electrical schematics available anywhere? I think this is volume 3, it is not online here: http://www.mr2-tech.com/bgb/mechanic...mechanical.htm
Thanks,
Bob
xmacdaddy is offline   Reply With Quote
Old 02-23-2006, 05:12 PM   #2 (permalink)
MRQtwinturbo's Avatar
View MRQtwinturbo's Photo Gallery
coolant temp sensor..in the engine bay...
http://www.mr2oc.com/showthread.php?...nt+temp+sensor
91 mr2..07 335i..
MRQtwinturbo is offline   Reply With Quote
Old 02-23-2006, 05:51 PM   #3 (permalink)
Great, THanks for the link. Still discovering all the MR2 sites.
Here is a link for electrical schematics and troubleshooting:
http://www.mr2-tech.com/bgb/mechanic...efi_system.htm
Old 02-24-2006, 02:59 AM   #4 (permalink)
View silentmr2turbo's Photo Gallery
ware could i pick up a cheap sensor to fix mine mine is broke too
silentmr2turbo is offline   Reply With Quote
Old 02-24-2006, 08:06 AM   #5 (permalink)
are u sure its broken...it pops loose all the time..try jiggling it around and see if it still works...if not..dealership is only place for it..
91 mr2..07 335i..
Old 02-24-2006, 12:38 PM   #6 (permalink)
It is the sensor. I just tested it. Using and Ohm meter from the sensor to ground give infinite resistance. Also shorting wire to guage to ground makes guage go hot. Just picked up a repalcement at Toyota dealer. Part number is 83420-20020. Just about to put it in.
Old 02-26-2006, 01:14 PM   #7 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
I replaced my temp sensor last fall. went dealer first. they wanted $21.00. and they didn't have it in stock. then I went to O'Reileys and I think it was $14.00 and they had it in stock. works fine...
The Jedi Speeder at CarDomain
Toyota Engine code vivian General Discussion 22 12-27-2008 01:16 AM
engine miss on long drives FifthCamry Camry & Solara Lounge 6 04-06-2005 07:00 PM
Engine Temp terrynham Camry & Solara Lounge 6 05-07-2004 06:56 AM
temp guage silverstreakin Celica Forum 2 03-03-2004 07:37 PM
optimum engine temp Tosh Hardcore Tech and Competition 8 01-04-2003 12:11 PM
