line in between Intk manifold and map sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2006, 10:22 PM   #1 (permalink)
View jesse0880's Photo Gallery
i noticed the vacumm line inbetween the intake manifold and the map sensor (the sensor next to the diagnostic port) has a jet in the middle of it. in my mannual there is no sign of a jet designed to be there. is the jet there on any one elses car?
jesse0880 is offline   Reply With Quote
Old 02-24-2006, 08:09 AM   #2 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Do you have the turbo model?
If so, there is nothing from the factory on that line.
It just is a direct vac line from the manifold to the MAP.
Some people cork that line to get rid of fuel cut.
What do you mean by a "jet."
Does your factory boost gauge work?
All the MAP sensor does is control fuel cut and the OEM boost gauge.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 02-24-2006, 01:44 PM   #3 (permalink)
yes, its a 91t with the tdo6 on it. my mannual calls the little circular plastic thing ( like the one on the vacum line going to the by pass valve) a jet. i just bought a boost gauge and i used the line going to the map sensor for the gauges source and all it gives is vacum. but ill put a straight line on and see what will happen.
Old 02-24-2006, 01:49 PM   #4 (permalink)
I love Cin
It sounds like they put in a check-valve.
It allows air flow one way, but not the other.
I would say to get rid of it.
Old 02-24-2006, 02:21 PM   #5 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
Mine has that too...... weird... JDM Gen2 3SGTE... what motor do you have?
Old 02-26-2006, 01:27 PM   #6 (permalink)
maybe. when i bought the car for 500 bucks, the head on the original motor was warped beyond repair so i bought a 3sgte from japan. so im not sure which motor that vacum line is from so i'll say probably
2000 Solara check engine light mytoyota02 Solara 25 10-16-2011 12:06 PM
Group Buy for PSC1 (15 more HP) Pb 2nd Generation (2005+) 82 12-24-2008 10:33 PM
MAP Sensor? Code 31. Does my car have one? 94celica94 Celica Forum 9 02-10-2005 10:37 PM
