What head gasket to use? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-24-2006, 05:50 PM   #1 (permalink)
View madfastmr2's Photo Gallery
I have a 91 2.2 liter non turbo 5SFE and I just purchased a turbo that came off of a 3SGTE. I was told by the person who sold it to me that I would need a new metal head gasket that would increase the distance of the cylinder head from the block in order to lower the compression and compensate for the newly installed turbo. He wasnt specific where to purchase this nor did he give me any specs on what thickness the gasket should be. Not too sure if this is even correct so any info would greatly be appreciated.
Thanks in advance
madfastmr2 is offline   Reply With Quote
Old 02-26-2006, 01:09 PM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
you do need to lower you compression to go turbo in order to avoid detonation. a cometic gasket will work great. go with the thickest one.But I hope you have all the neccessary hardware to make your N/A accept the turbo.. thats quite an under taking and far from just "slapping on" a turbo. do you have the right ex. manifold, fuel enhancement, Intercooler, oil lines, water lines, vacuum lines, boost gauge, boost controller, down pipe, exhaust piping? and forged pistons would be reccomended too. some of the others that have done swaps may elaborate more...
The Jedi Speeder at CarDomain
Old 02-27-2006, 11:56 AM   #3 (permalink)
Thanks for the heads up MR2BAD - I just got off the phone with cometic and they recomended the right gasket. As far as all the parts go, I have the manifold, fuel enhancement, Intercooler, oil lines, water lines, vacuum line, down pipe and exhaust piping. Im working with a shop that is helping me out. It is quite an undertaking but with some time and patience im sure it will all work out. If there is anyone out there that has performed this swap chime in with your 2 cents...Thanks again MR2BAD!
Old 02-27-2006, 09:56 PM   #4 (permalink)
El Capytain
View HighSpeedScene's Photo Gallery
man...with as much money as that's going to cost you, you might just want to buy a 3s-gte and swap it in.
HighSpeedScene is offline   Reply With Quote
1993 4 runner head gasket blown! peanutzz 4Runner Lounge 4 02-15-2006 10:45 AM
Head gasket theory needed peterng 89-95 Toyota Pickup/Hilux 4 01-15-2006 09:51 PM
head gasket ladydanyell Camry & Solara Lounge 10 09-27-2004 05:45 PM
