I know not everybody reads the other board so,
Well here is another update: I have started on the wireing and installing the intercooler setup. Please keep in mind the car is still far from finished but I want you guys to see how short the IC pipes are going to be :devil: As you can see the wires for the EMS are all going to be run under the throttle body and down the IC pipe. That way they will be practically invisible when the engine cover is open, it also happens to be the shortest run for the wires to the EMS. Im sorry about the fuzzy pics but I snapped them with my phone while I was working on the wireing.
Anyway on to some pics.
This is the hole for the pipe that enters the trottle body surrounded by a flexible rubber gromit. This should prevent damage to the pipe in the event that the motor torques more than I expect or TRDNY makes 500 ft/lbs with this beast in the first week of tuning LOL. The pipe can also move up and down in the oval shaped hole thereby reducing the ammount of flex the top coupler has to deal with.
Here you can see the single pipe custom bent to fit so that there will only be two couplings on this section.
A blurry shot of the IC core from under the car. Notice the flexable rubber sealant around the IC. very air tight. There will probably be a scoop to help ram air up through the core at speed and I also plan on building a baffel in the trunk to assist the air exiting the IC core.
Another shot while pulling wires. Im going to fab up the rest of the IC pipes tomorrow after I finish the wireing. Yes the outlet pipe has paint on it, ill clean it off tomorrow.
