Do you have a boost controller.
(I guess, yes)
Did you remove the T-VSV when install the controller?
7 psi (wastegate spring setting) is not low. It's normal boost.
T-VSV actually allows boosting above ~7psi by bleeding air out of the actuator.
In your case, it didn't boost more than 7 psi because the T-VSV did not allow it.
Unsuitable condition can directly and indirectly causes this.
(too high temp, too low temp, excessive knock, etc..)
93 ST185
