Weird sound help... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2006, 01:23 PM   #1 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
View Zero turbo's Photo Gallery
Question Weird sound help...
I nave a weird sound coming from under the shifter is like 2 foot below the radio.Its hard to explain . the sounds gets worst when you put medium acceleration on the car and when you fully put the pedal down it goes away and if you cruise it dosent sound.If you press the clutch it dosent do anything, it continues to make the sound.So i think is maybe a heat shield or something because sounds like 2 metals vibrating.So i need help thx!!
1-Chuck Norris is the reason why Waldo is hiding
2-When Chuck Norris does a pushup, he isn’t lifting himself up, he’s pushing the Earth down
3-The Guinness World Book of records shows the people that have come the closest to the skills of Chuck Norris.
Zero turbo is offline   Reply With Quote
Does your engine make this sound when cold? montreal 9th Generation (2003-2008) 69 05-05-2009 08:10 PM
Does your engine make this sound when cold? montreal 1st Generation (2003-2008) 52 12-29-2007 07:56 AM
*FIXED* Does your 2az-fe sound like this? -Sound clip- Dan0717 Camry & Solara Lounge 25 09-05-2006 09:06 PM
squeaking sound? wild2taz Camry & Solara Lounge 8 04-07-2005 11:34 PM
94 Camry V6 - Buzzing sound at first forward motion clicq 3rd & 4th Generation (1992–1996 & 1997–2001) 3 03-15-2005 05:28 PM
