Header leak.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-06-2006, 02:06 PM   #1 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
View Zero turbo's Photo Gallery
Header leak..
Scince i bought my MR2 he had 2 little holes right where the weld of the external wastegate joins to the header.So i was at the strip racing(what a miracle ) and I miss 4th
and somehow get 2nd and my rpms go well beyond 8,000 and now I got the little holes on the weld expelling a good amount of air and my car cant hold 15 psi to read line. i get 15 psi for about 1 second and at 5,700 it goes back to 12-13psi. so should i just get the holes weld up(they are very small) or buy a new racing header .THX!!!
1-Chuck Norris is the reason why Waldo is hiding
2-When Chuck Norris does a pushup, he isn’t lifting himself up, he’s pushing the Earth down
3-The Guinness World Book of records shows the people that have come the closest to the skills of Chuck Norris.
Zero turbo is offline   Reply With Quote
Old 03-06-2006, 08:08 PM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
First of all, it is called exhaust manifold, not header.
You should fix the manifold.
What turbo are you running?
I'm also wondering what size and where the missing metal piece from the manifold went?
If it went to the turbo, it might chip the turbine wheel.
93 ST185
ST185 is offline   Reply With Quote
Old 03-07-2006, 11:15 AM   #3 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
well i am using the ct-26 is stock and the exhaust manifold didnt lose anything , it just has 2 little holes where the external wastegate joins the manifold so i will just weld the 2 holes.
Old 03-08-2006, 08:58 AM   #4 (permalink)
Noob :-)
CT26 and external wastegate?
Did you weld the stock wastegate shut?
Anyway, may be it is the tubo that causes the boost drop.
93 ST185
Old 03-08-2006, 12:44 PM   #5 (permalink)
aka "Downforce"
View Strat42586's Photo Gallery
Yeah, I missed shifting from 4th to 2nd once in my old 97 Prelude. It shot the RPMS to an insane level and caused the pistons to kiss the valves. I had to pull it apart and fried 2 pistons, 8 valves and the seals around everything. Your problem might be more than just your exhaust manifold.
::EDIT I don't know any reason why your stock turbo should ahve an external wastegate. Seem sketchy, so that setup could also spawn problems.
Strat42586 is offline   Reply With Quote
Old 03-08-2006, 04:05 PM   #6 (permalink)
92 MR2 Turbo
Zero turbo's Avatar
I bought the car with the external wastegate is a Tail.The wastegate is dumping to the air.The wastegate is not weld shut.What can happend with this kind of setup? Should i change the external wastegate to a internal wastegate?
Mysterious oil leak + wierd sound.. see pictures Mins Archived Corolla threads 5 01-20-2006 11:05 PM
I have a Rad fluid leak help me Loan Wolf Cam87 Camry & Solara Lounge 8 04-30-2005 02:19 PM
Pacesetter Gen2 header installed white90dx 1st & 2nd Generation (1983–1986 & 1987-1991) 8 04-06-2005 09:55 PM
