Blowing Fuses - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2006, 01:25 PM   #1 (permalink)
View sclappart's Photo Gallery
Blowing Fuses
I did a couple searches and nothing popped up
93 MR2, non turbo...
About a week ago it started blowing the 7.5 amp fuse labled ECU / IGN pretty consistently, sometimes it will go a few days and sometimes it will pop 3 in a row almost as fast as I can put them in. I found a wiring diagram but I'm not really having any luck sorting this out, any help or suggestions greatly appreciated!
sclappart is offline   Reply With Quote
Old 03-10-2006, 04:18 PM   #2 (permalink)
View danboy's Photo Gallery
I had that problem to,theres a wire that chaffs through somewhere and shorts out, it was on the starting circuit on my car. I spent ages trying to find the cause of the problem, but had to give up in the end, because there was just so many wires, all similar colors,so although you might have a wiring diagram, it isnt much use for trying to follow the wires through the car! fortunatly for me the fuse stopped blowing, and i just had to run a new wire to the starter relay. But I recomend getting a toyota specialist to try and find the problem, for safety reasons, because if you do have a wire shorting out, your MR2 could start getting a lil smokey.
If your lucky, by ringing around you may find a specialist who may know of a common cause for this to happen and point you straight to it
danboy is offline   Reply With Quote
Fuses keep blowing out... Help RedPhoenix Audio, Video, and Security - Tech 9 08-06-2005 10:57 PM
Keep Blowing fuses. Phreshnphunky Archived Corolla threads 9 11-16-2004 05:36 PM
keep blowing fuses dna59 Camry & Solara Lounge 2 10-04-2004 06:02 AM
Blowing Fuses MoeHowardDavid General Discussion 4 08-31-2004 04:09 PM
