O2 Sensor Help!!...... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2006, 11:49 PM   #1 (permalink)
1 FST MR2 430 WHP @19 PSI
turbonatormr2's Avatar
View turbonatormr2's Photo Gallery
I have a Bosch o2 sensor that I am trying to splice into to connect to the stock sensor connector. Does anybody know which wires to splice into to make it work properly.
Here is what I have
On the Bosch sensor, the wires are as follows:
2 White wires are for the heater. 12v, it doesn't matter which is + and which is -
Black is EGO + signal
Gray is EGO - signal
On the stock 02 sensor itself the wires are as follows.
1 blue wire
1 white wire
2 black wires
turbonatormr2 is offline   Reply With Quote
Old 03-12-2006, 04:31 PM   #2 (permalink)
Here is what I have
1 blue wire
1 white wire
2 black wires
Anybody. Here are some pictures of the two sensors. The black one is the Bosch 02 sensor and the grey one is the stock Mr2 sensor.
Old 03-13-2006, 04:45 PM   #3 (permalink)
View Gairloch's Photo Gallery
I have a single wire O2 sensor so I'm afraid I can't help you. What you might be able to do is dig into the BGB and find out what the wires are then use a multimeter to identify the right ones on your Bosch sensor.
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
OBDII codes Phi Hardcore Tech and Competition 12 12-24-2011 09:38 AM
Error code 21 O2 heated Oxygen Sensor failure pkmorreira 89-95 Toyota Pickup/Hilux 11 02-05-2011 03:02 PM
2000 Echo - O2 sensor failure Ashla Yaris, Vitz and Echo Forum 4 03-15-2006 03:48 PM
O2 sensor problem fox_prime Camry & Solara Lounge 2 09-09-2005 12:42 AM
