3SGTE rod bearings - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-20-2006, 06:40 PM   #1 (permalink)
tamalpro
View tamalpro's Photo Gallery
3SGTE rod bearings
i saw this rod bearings that said to be much better then OEM, they say they are much stronger and can tolerate heat much better, woul be a good idea to change my bearings atleast just for maintance? my 2 has 94k miles, im confident that it shouldnt be that hard [lees than 3 hours] the brand its named -King-
tamalpro is offline   Reply With Quote
Old 03-20-2006, 07:02 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
Did you know that toyota engines are blueprinted from the factory? If you call the dealer for the bearings they will ask you for codes that are stamped into the engine in various places. Do you think the aftermarket bearings will be correct if the dealer has to ask for these codes to get them correct? Unless you are cutting the crank I'd stay OEM.
雄のハヤブサ
Tercel GTS is online now   Reply With Quote
Old 03-20-2006, 07:49 PM   #3 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
don't change your bearings unless you're doing a full rebuild.
i have King Race bearings in my 2.1L stroker and they are very high quality bearings. the OEM bearings are aluminum, the King bearings are a tri-metal bearing.
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 03-24-2006, 12:09 PM   #4 (permalink)
I do NOT exist ...
View KAOS's Photo Gallery
yeah save it for when you need a rebuild. no need to tamper with it.
My pride and joy ...
KAOS is offline   Reply With Quote
1zz-fe Warning!!! Rod Bearings and Lubrication 2001rolla Hardcore Tech and Competition 12 07-14-2006 02:19 PM
Rod Bearings and Window....>.< importdriver007 Camry & Solara Lounge 0 11-28-2005 09:40 PM
What happened to these rod bearings (pics) 94_Rolla_Guy Hardcore Tech and Competition 5 07-18-2005 11:02 PM
7mgte rod bearings ag6286 Supra Forum 6 07-04-2005 01:02 PM
1990 auto 3SFE rod bearings swap in chassis? LoveLearn 1st & 2nd Generation (1983–1986 & 1987-1991) 5 01-26-2005 05:20 AM
