timing belt Q? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-23-2006, 09:53 PM   #1 (permalink)
View jesse0880's Photo Gallery
timing belt Q?
i'v replaced my timing belt twice because the belt keeps getting chewed up on the inside of the belt (side towards the motor). i'v checked the circular guild that goes next to the crank gear and its facing the way it says in the book (the concave surface towards the belt). i'v watched it idle without the cover and the belt is fine but after a couple of weeks of driving the belts begin to slip and timing is obviously screwed up. i will check the belt and its half way gone. what is goin on?
jesse0880 is offline   Reply With Quote
Old 03-24-2006, 05:52 AM   #2 (permalink)
View OEMonkey's Photo Gallery
Did you check both idler pulleys for bearing noise or binding, and replace the hydraulic tensioner(3sgte)? Check the oil pump gear too. Were any of the pulleys wobbly when you had it idling w/ the covers off?
OEMonkey is offline   Reply With Quote
Old 03-24-2006, 06:48 AM   #3 (permalink)
View extoytech's Photo Gallery
You mean the convex surface torwards the belt, if you have the dished part facing the belt it will eat your belt to pieces. >(l if this parenthisis were the guide and the L were the belt this would be incorect, >)l this is how it should look. Also alot of people have troulbe getting the tensioner tightened correctly, you may need to use a HUGE pry bar to push on the tensioner while someone else tightens it.
extoytech is offline   Reply With Quote
My Timing Belt Job (Pics) 56k go away Ken4 Camry & Solara Lounge 113 05-18-2011 09:06 AM
Timing belt tension spring's purpose AFTER belt install? awmccready Camry & Solara Lounge 4 09-20-2009 02:59 AM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
Timing Belt work mandyfig Camry & Solara Lounge 1 02-07-2005 08:35 AM
