overboosting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-26-2006, 08:56 PM   #1 (permalink)
View NU2MR2's Photo Gallery
overboosting
I installed a mbc on my turbo(just rebuilt and installed) and turned all the way down, so it would just run off of the wastegate, but my boost shot up over 15psi! I thought the stock wastegate was only so posed to let it boost to 12 tops? I don't want to kill my turbo...what can I do?
NU2MR2 is offline   Reply With Quote
Old 03-27-2006, 09:48 PM   #2 (permalink)
Noob :-)
View ST185's Photo Gallery
Make sure all vacuum lines are connected properly, especially on t-vsv side.
Most people forget to plug that port.
93 ST185
ST185 is offline   Reply With Quote
Old 03-28-2006, 06:08 AM   #3 (permalink)
I'll have to check that, but I won't get to work on it unntil this weekend. Thanks.
Old 03-28-2006, 03:59 PM   #4 (permalink)
Where exactly is this?
Old 03-28-2006, 10:43 PM   #5 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
what do you mean by-"so it would just run off of the wastegate" ?
The Jedi Speeder at CarDomain
Old 03-29-2006, 06:58 AM   #6 (permalink)
The stock wastegate is soposed to keep it under 11.8 psi, right? Well, I figured if I turn the boost controller all the way down; it should run stock boost and I wouldn't have any problems. But it's overboosting...so the wastegate isn't opening right(enough, whatever) so there isn't enough air bypassing the turbo, and I want to drive my car without the fear that she'll blow! Any ideas?
Old 03-29-2006, 07:38 AM   #7 (permalink)
Noob :-)
Stock max boost is 11.8 psi when TVSV is open.
Normal boost range is 7.1-11.8.
There are two vacuum ports on the wastegate actuator.
One is connected to the compressor housing.
This is the one you should connect it to the MBC.
The other port is connected to the t-vsv.
You need to disconnect the hose going to t-vsv and plug it.
Otherwise, it will just keep bleeding air out of the actuator.
93 ST185
Old 03-29-2006, 08:06 AM   #8 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
ST185 is correct.
The stock wastegate pressure is just over 7 psi.
The T-VSV bleeds air so you can run more boost than that.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 03-29-2006, 09:05 AM   #9 (permalink)
Thanks, I didn't check that...The mbc is connected to the correct line, but I never even thought to look at the other one. I cant wait to ride in her again ! That test was the first time since last fall.
Old 03-30-2006, 03:25 PM   #10 (permalink)
Well I got a chance to work on it today, and I fixed the overboosting problem...but I discovered a coolant leak on the line that runs to the oil cooler; so now I have to take it all apart again and fix that!
But after that I should be set!
Old 03-31-2006, 06:32 AM   #11 (permalink)
Noob :-)
Ahh.... HFH have fun with that.
93 ST185
Old 03-31-2006, 09:02 AM   #12 (permalink)
No kiddin...at least it's new parts, so it shouldn't be that bad.
Mr2 Overboosting problem closmr2 MR2 Forum 8 05-04-2005 11:26 PM
MR2 overboosting problems need help BAD! IMPORTMyth01 MR2 Forum 4 01-18-2004 05:57 AM
