car stutter??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-28-2006, 05:32 PM   #1 (permalink)
View vietn712's Photo Gallery
car stutter???
HI GUYS I NEED SOME HELP HERE..i got my 91 mr2 swap with a 93 turbo just a couple months ago..the first few months, the car runs great..then here comes the problem..in the morning when i start the car it doesn't start right away..it turn on then shuts off..i have to start it again then it start..ti happenes everytime i started it in the morning..then the worst part is it stutter..it just doenst want to go..then after about 5-10 minuts of driving then its back to normal..is it bc the turbo is still cold?..there is another prolem...if i drive it n pull it a lot..the engine or soemthing puts out a HISSING sound..sounds like air or something is leaking..i can't seem to find the souce of the sound..help me out guys..thanks
vietn712 is offline   Reply With Quote
Old 04-03-2006, 02:54 AM   #2 (permalink)
TN's Hapa Haole
MR2Jedi's Avatar
Gameroom cash: $997475
iTrader Score: 6 reviews
View MR2Jedi's Photo Gallery
the turbo does need to heat up. even though temp gauge says engine is warmed up, the turbo needs to be hotter. you don't want to get on it until then. does it make the hissing sound at idle? or just under boost?
The Jedi Speeder at CarDomain
Old 04-03-2006, 05:55 AM   #3 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Sounds like a healthy vac leak somewhere in your system.
Start checking your intercooler hoses, the BOV ... make sure the big hose that connects to the front of the turbo is nto cracked.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Old 04-04-2006, 04:03 PM   #4 (permalink)
View Gairloch's Photo Gallery
Vacuum leaks seem to be the issue of the month. How can you track vacuum leaks down other than visual inspection?
"Our Lady of Blessed Acceleration, don't fail us now!" -Elwood Blues
Gairloch is offline   Reply With Quote
Old 04-04-2006, 10:21 PM   #5 (permalink)
it might be a vacume leak like u said..you can hear the hissing sound after i pull it a lot...that sound will stay there as long as i drive it..but if i drive normally then nothing happened
Old 04-04-2006, 11:08 PM   #6 (permalink)
I love Cin
http://mr2oc.com/showthread.php?t=8961
Old 04-04-2006, 11:26 PM   #7 (permalink)
View Mike@Fidanza's Photo Gallery
you can buy a smoke machine for $1000.00 or you can try and find a good mechanic that has one! used one today! worked awesome!!!!!!!
and no, it's not the kind of smoke machine you're thinking of! hahaha
Mike@Fidanza is offline   Reply With Quote
MKIV Scam registry bmw5002 Supra Forum 11 07-09-2010 11:59 PM
For Sale: 1991 Toyota MR2 non-turbo automatic (many pics) LarryDallas Vehicles 2 07-07-2005 03:15 AM
Woah!! Glowing Red HOT pipe under hood? Neog2 Camry & Solara Lounge 37 01-12-2005 01:16 AM
Most customized camry i've ever seen..... Zeek321 Camry & Solara Lounge 68 10-14-2002 11:35 PM
