I Dynoed My Turbo Set Up Today - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-31-2006, 06:27 PM   #1 (permalink)
1 FST MR2 430 WHP @19 PSI
turbonatormr2's Avatar
View turbonatormr2's Photo Gallery
Ok I dynoed my new turbo set up and this is what I got. This was at 19 pounds of boost.
turbonatormr2 is offline   Reply With Quote
Old 03-31-2006, 06:47 PM   #2 (permalink)
View 1quickmr2's Photo Gallery
wat kind of turbo are u running
1quickmr2 is offline   Reply With Quote
Old 03-31-2006, 07:35 PM   #3 (permalink)
3SGTE & 1GRFE
View NESW20's Photo Gallery
nice numbers. what do you have in your block?
-Mike
1991 MR2 Turbo 2.1L stroker
2006 Tacoma D-cab 4x4 Auto TRD Off Road
NESW20 is offline   Reply With Quote
Old 03-31-2006, 08:27 PM   #4 (permalink)
View clem's Photo Gallery
great numbers dude
clem is offline   Reply With Quote
Old 04-01-2006, 06:40 PM   #5 (permalink)
I am running a Garret GT30 dual ball bearing.
Old 04-01-2006, 06:44 PM   #6 (permalink)
Originally Posted by UfoZ
mod list?
My mod list.
MY MOD LIST
304 WHP @ 9 PSI
344 WHP @ 14 PSI
370 WHP @ 17 PSI
430 WHP @ 19 PSI
9000 RPM'S
Engine built by Chris-K (www.enginelogics.com)
MOTOR- 3SGTE 2.0
Every single gasket was replaced.
Full street port (Block ported)
Magnaflux, bore and oil gully mod block
Chrome Molly Ductile Sleeves
Micro polish, Straighten, Chamfer and balance crank
Clevite 77 bearings std
Forged Pauter Rods
Cp pistons forged
Ported Oem oil pump
Ported cylinder head
34.5 mm ferrea intake valves
30 mm ferrea exhaust valves
65 lb valve springs with titanium retainers
MRS shim-less buckets
Custom intake manifold
Arp head studs
Arp fasteners
Hks 272 intake cam
Hks 264 exhaust cam
Cold start injector eliminated
Aem cam gears
TTE metal head gasket
Egr block off plates (ko racing)
Apex blow off valve
Fuel
Wolfkatz fuel rail (bored at 9mm) (www.wolfkatz.com)
Adjustable fuel pressure regulator (Paxon)
850cc blitz fuel injectors (www.horsepowerfreaks.com)
Toyota supra fuel pump in gas tank (www.toyotacountry.com)
Intake
Custom 4-inch intake (www.turbohoses.com)
Ignition
Ngk spark plug wires (rctx69)
Rotor and cap (Stock)
Indurium spark plugs (gap 0.28)
Intercooler
Greedy with 7.5 fan and fan shroud (fan shroud made by Hux-Racing) (www.huxracingusa.com)
TRD thermostat high performance low temp.
Transmission
Lsd
Light weight Fidanza fly wheel (www.horsepowerfreaks.com)
Spec clutch with upgraded pressure plate (www.chicoraceworks.com)
Extended clutch slave cylinder pushrod (www.speed-source.net)
Red Line MT-90 Gear oil
Turbo
Garrett GT30 ball bearing turbo with .70 compressor A/R and .82 turbine A/R with Custom thermal coating tubular manifold and tail 46mm wastegate. Thermal coating dump tube routed back into the 3 inch thermal coated down pipe with flex tube. Steel braided oil lines and water lines.
Exhaust
3 inch single exhaust KO-T1 (www.koracing.net)
EMS
Nemesis (Installed and tuned by Ricky-B) (www.mrcontrols.com)
Tuned on 91 Octane and 14 pounds of boost
Tuned on 91 octane and 17 pounds of boost
Electronics
TurboX type H Bov
Greddy turbo timer
Rims and tires (Nexen N-3000 ZR) High performance
Front 215/40/17x7.5
Rear 235/40/17x7.5
Miscellaneous
Valve cover allen bolts
Chrome TRD oil cap
Engine anti torque bar (www.vmaxperformance.com)
Motor mount inserts (kirkosaurus) (kirkosaurus@comcast.net)
Cusco tower brace (front and rear)
Auto meter boost gauge and pod
Auto meter Air/Fuel gauge and pod
White indaglow gauges
Chrome Bazel around gauge cluster (www.custombezels.com)
Heat wraps for down pipe and dump tube
Short shifter (OBX)
Custom Steel braided water, and oil lines. (www.rbisj.com)
Optimus battery
Adjustable RPM shift light (www.summitracing.com)
Carbon Fiber engine lid with dual 11 inch fans
Linos rod prop kit for the engine lid
Old 04-01-2006, 06:45 PM   #7 (permalink)
Originally Posted by clem
great numbers dude
Thanks Man. I only did two pulls on this one and both pulls were done on 3rd gear.
Old 04-01-2006, 06:55 PM   #8 (permalink)
-Mike
you can find more info ont he car here also with pictures of the motor.
http://www.mr2board.com/forums/vbpic...p?do=view&g=72
Old 05-28-2006, 12:51 PM   #9 (permalink)
tamalpro
View tamalpro's Photo Gallery
big list
man thats such a big list i bet you spend a weekend posting all your mods, nice
tamalpro is offline   Reply With Quote
Old 05-28-2006, 12:53 PM   #10 (permalink)
tamalpro
max psi
hey whats ther max psi you can get from your turbo?
Old 05-28-2006, 01:15 PM   #11 (permalink)
400whp club here I come!!
Piddy's Avatar
View Piddy's Photo Gallery
I'll take one of those. I love your car. Very modestly done .
Got my new set of Xenon bulbs today iamfob General Discussion 12 04-30-2002 11:23 PM
