Originally Posted by Jay-Spec
My speedo is not working, i have a A/T, iam asuming that the guys just forgot to connect something because the tranny was replace not to long ago. Also my O/D lights flashes alot after driving the car for a while, Can some one tell me where the speedo cable is or the connector, or if u had this problem a little help please.
The speedo cable is a heavy looking cable that looks almost like a coolant line that runs closest to the drivers side engine mount. If it's anything like the manual transmission the speedo sensor is pretty much right above the rear motormount.
What year is your car? '91-'92 had a mechanical speedo sensor and '93+ uses an electronic.
Your instinct of checking to make sure that it's actually plugged in after a tranny swap is a good one. I wouldn't start tearing your dash up until you've verified that everything is in place. Have you talked to the transmission shop to see if they'll fix what is likely their mistake? If it was working before you went in and now it's not it's extremely unlikely that there's anything wrong with the dash or the cable itself.
