Apexi SAFC II Tuning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-03-2006, 10:28 PM   #1 (permalink)
View Mike@Fidanza's Photo Gallery
Anyone here have one of these?
Anyone here know how to use it?
I am aware in order to properly tune the vehicle with this unit you must have a dyno, but the dyno guy over here doesn't know too much about it...
Thanks!
Mike@Fidanza is offline   Reply With Quote
Old 04-03-2006, 11:08 PM   #2 (permalink)
1 FST MR2 430 WHP @19 PSI
turbonatormr2's Avatar
View turbonatormr2's Photo Gallery
Thanks!
I would not recomend using this unit for the following reason. I am not a big fan of piggy backs.
Piggy backs cons.
-REMOVE FUEL, ADD TIMING:
This is by far the LARGEST concern on SELECTED piggybacks. When you use the piggyback to control larger then stock injectors you typically interface the MAF/AFM/MAP sensor and modify the signal going to the ECU. So say you have to pull fuel because your larger injectors are dumping to much fuel what happens is the ecu thinks there is LESS air entering the engine thus thinking there is less LOAD, well less load means that its safe to advance the timing to help with combustion. While this is fine for when you really are not putting a large load on the engine (IE off boost), this can be DEVASTATING to your engine in that since the timing has been advanced in a high load area the chances of detonation is greatly increased!
This is why I DO NOT recommend the S-AFC unit to anyone because of the fact it cannot control timing (or at least have the ability to retard it).
turbonatormr2 is offline   Reply With Quote
Old 04-03-2006, 11:19 PM   #3 (permalink)
I'm not using it to control larger injectors. i'm using it to lean out the AF a bit at higher rpm/boost levels. on the dyno last year it was running way too rich. i adjusted the timing a bit and still ran too rich. it's just a temp. thing!
Old 04-04-2006, 07:20 AM   #4 (permalink)
I love Cin
JekylandHyde's Avatar
View JekylandHyde's Photo Gallery
Mike, the SAFC is a fine piece of equipment to use on most cars.
There is an inherent risk in using one on the 3SGTE.
The SAFC leans out fuel by lying to the ECU about the amount of air coming in through the AFM. Our ECU's, when they see less air coming in, start to ADVANCE timing.
advanced timing + leaned fuel + more boost + high rpms = BOOM
Many MR2's 3SGTE's have died this way. I ran an SAFC for several years with luck, but I was always using race gas and water injection. You do not need a dyno to set up the SAFC, but you do need a wide-band O2 sensor.
_____________Sponsorship: Amateur Motorsports_____________
JekylandHyde is offline   Reply With Quote
Cost to install Apexi SAFC II? cman2000 General Discussion 10 12-08-2004 11:28 AM
5fse SAFC II tuning? 5speedman Camry & Solara Lounge 2 09-22-2004 10:11 PM
5sfe SAFC II tuning question 5speedman Hardcore Tech and Competition 1 09-22-2004 09:44 PM
